Release reel:
Happy Thursday @Community,
we have some good news for you:
Speckle 2.14 has been released:
As always:
- you can update most Connectors from Manager
- make sure you update all your Connectors at the same time
- let us know if you find any bugs!
Below a list of the most relevant changes.
Connectors
Advance Steel
- We’re excited to announce the
alphaversion of a new connector that was entirely developed by community member @phliberato
Revit
Parameter Updater enabling you to send data from Excel to Revit (and vice versa), facilitating manual data entries.- Tutorial coming out soon!
BREAKING CHANGE: Objects being sent are now grouped in Collections, read more about the change. -
Openings in analytical surfaces are now supported in Revit 2023
We have improved how baselines of columns are handled thanks to your feedback
You can now send elements based on Revit Filters, kudos to Chuong Ho for the contribution
- For this reason, we have deprecated the “Parameter Filter”
DirectShapes can now be updated correctly from GH and Rhino
Improved Stability (sudden crashes have been reported)
Fixed a bug that was preventing correct mapping of structural types on receive
Fixed a bug that prevented very large model groups from being sent and that made the upload very slow
PowerBI
Data Connector
- New
Commit Object IDcolumn in GetByUrl result table. This is needed for the latest version of the 3D Visual
3D Visual
- Switched from loading individual objects to loading commit objects (using
Commit Object IDcolumn)- Faster loading and faster user interactions when slicing/filtering.
- Separated color and tooltip logic into 2 inputs (
Color ByandTooltip Data) - Sorting support
- Support for multiple selections using shift (classic) or ctrl/cmd (PowerBI’s default)
- Consistent coloring based on sorting order in visual.
- Improvements in bi-directional selection.
- Moved context menu from double-click to right-click
- Fixed HDRI issue causing models to appear too dark.
- Fixed issue with languages other than English not coloring/filtering
Rhino
Speckle Mapper
- There is now a dedicated
UI button - Updating of DirectShapes with materials on receive in Revit has been improved
- Wall by face, wall by profile have been added to the list of mappable Revit elements
- We have also improved selections and UI/UX
- And we also have added support for planar curves
Added support for collections
We fixed a bug that prevented user attributes to be set on block instances on receive
Grasshopper
There is now a new node to flatten Collections
- Returns a flat list of all deeply-nested collections inside a given Speckle Model/Collection allowing for easier access to the objects within them.
SketchUp
There is now a Speckle Mapper inside SketchUp, it allows you to send meshes as DirectShapes to Revit
- We have improved our conversions to give you even more reliable geometry transfers between Sketchup, Revit, Rhino, Blender and QGIS.
Blender
We have improved how instances are handled
Implemented support for new Collection structure
Navisworks
Navisworks 2024 support -
Collections alignment with other Connectors and web for consistent data access -
Specific AutoCAD geometry primitives supported (2D/2.5D): blocks, arcs, polylines -
Stability improvements &
Bug fixes
ArchiCAD
- Roof & shells are now supported on send and receive
Levels are now supported as well
We have improved how Meshes look and are received
Excel
Parameter Updater enabling you to send & update data from Excel to Revit (and vice versa), facilitating manual data entries.
QGIS
- You can now create and send 3D buildings with the correct heights for context models!
- You can also create and send 3D terrain models
- And the best part: you can generate a full context 3d model by putting the texture over your terrain, projecting buildings onto it, and extruding by the custom attribute!
Supporting CRS with other units then ‘meters’
New triangulation algorithm for sending polygons
Small improvements: receiving latest commit without refreshing the plugin, more stable behavior of sending/receiving in the background, removing redundant saves of the custom user CRS, sending nested layer groups, mesh faces orientation normalized for display in other 3d software, clearer error messages.
Server & Web
Frontend
We are working on a brand new frontend! Watch this space
3D Viewer
- Implemented batch splitting. Max batch size is based on available hardware capabilities
- Implemented dynamic object level transforms while still rendering objects batched. Support for all WebGL versions
- Bottom level acceleration structure via per-object BVHs
- Top level acceleration structure via per-batch BVHs
- Custom material system revamp
- Implemented multi-viewer support on the same page
- Added support for numeric line filters
- Fixed the issue with section plane helper box jitter when far from origin
- Added object explosion support
- Reduced memory footprint a bit
- Instances fixes
- Support for speckle type inheritance in the Converter
- Filtering fixes
- Instance and Block selection fixes
SDKs
.NET
- Support for Collections, read more about the change.
