All to do with visualisation - Houdini is quite good for generating procedural textures, effects, physics etc and so having a connector where you could take things either from an AEC platform (Revit, Rhino, ArchiCad, Sketchup, etc) into Houdini, or something non-AEC (Blender, Maya, Mudbox, etc) would be useful. It would also be cool if speckle allowed for the transferring of maps and texture packs as well (potentially as attributes on objects with links stored to the textures). Currently transferring textures between software is a total pain and it would be great to see this process streamlined a bit (acknowledging that things like Megascans and itās plugins already exist).
Bump. I am hearing more noise about Plant 3D in relation to the Water industry across ANZ and even unprovoked noises about DEXPI. Perhaps we can talk about this more? (P.s. this is Aurecon talking somewhat here)
Hi @Matthew_Randell ,
Thanks for the bump
As you can see from our survey above we have quite a few software in our backlog
Having said that, since Plant 3D is based on AutoCAD, maybe thereās something we can do fasterā¦
@clrkng would we be able to port the current plugin over there?
5 posts were split to a new topic: Revit Point Clouds not visible on viewer
We could add this to the open issue on additional AutoCAD verticals, I believe Architecture is also requested at the moment ![]()
#1 Community request for Navisworks has reached an alpha release. Now available from Manager.
I would be interested in seeing a connector for Deltek. The ability to pull information from a project database would amazing! Applying seals, EOR/AOR info, staff assignments, etc.
As far as new connectors, Iād love to see
- Solidworks <-> Speckle
- Maya <-> Speckle
- Speckle ā Navisworks
I would love to be able to send a customer provided Navisworks file
directly to Speckle ! (Like IFC)
And be able to stream it down to Blender, Bricscad, Vectorworks,
Modo, C4D, ā¦
As it is very unlikely that my customerās-customers would ever ever
install a Speckle Manager/Connector just to help collaboration with me ā¦
(they seem to love or not care about their proprietary closed BIM situation)
Please add Plant3D to vote list ![]()
For file upload options weāre limited to conversions made possible by open source file parsing right now.
If Iām correct, Plant 3D is an AutoCAD vertical, just like Civil 3D, meaning it might require very little effort to get a basic Connector goingā¦
Maybe this could be someoneās holiday Speckle hack? ![]()
What about Inventor ?
Inventor is a popular request for sure.
I have just started looking at documenting using the Navisworks Connector as a means of ingesting Inventor models, but thatās just one-way and for assemblies.
How do you see yourself using it in a workflow? What features would be most important to how you use inventor?
Plaxis for geotechnical engineering analysis
Hi everybody,
I would really appreciate a connector from 3dsmax to Unreal.
(sorry for the Unity tag. I had to put one but there wasnāt a 3dsmax tag nor an Unreal one)
I see multiple requests for Plant 3D, so I would assume many would also like AVEVA E3D!
Civil engineering and building design is not well integrated with technical industrial plant design.
Thanks for the upvote @fsdalen.
For the time being, the main way we are seeing AVEVA content coming into Speckle is via the Navisworks connector.
Houdini, yes highly needed!
I know itās a slightly more tricky one, but any updates on whether there could be a connector for IES VE? Would save loads of time rebuilding geometry ![]()
