There may be a possibility for a connector for IES VE, but it depends on several factors:
API Availability: Some software lacks an API, which means we cannot build connectors for those platforms.
Interest Level: If there is significant interest in a connector for a specific application, it affects our prioritization.
Use Cases: If there are enough workflows that would benefit from such a connector, this also influences our decision-making process.
Additionally, if you are familiar with how to interact with that application’s API, you might consider developing the connector yourself. That’s an option to keep in mind!
To supplement what @gokermu wrote, the IES team were investigating creating their own Soeckle connectivity I suggest you request this also with your contacts there to amplify the initiative.
Or how else do you feel a need for Trimble connectivity? We can share your thoughts with @David_Lash as well. We aren’t cold to the suggestion, but from both sides, we’d want to hit the most valid use cases.
