hnouri
(Hadi Nouri)
19 May 2024 10:52
1
Hello
Is there any solution to transfer 2D drawings from AutoCAD or Revit to Speckle?
2D elements are certainly supported from AutoCAD to Speckle, if you are referring to Paperspace transfer, I suspect you might be if you are referring to Revit drawings, this is not on the immediate roadmap for us, but if you take a look around, others are suggesting this and seeking your vote in support of their ideas:
Hi guys! Thanks for amazing work you are doing!
It would be great to have better support of drawings. Here is what i mean:
Hatch support
Better dimensions display - at least readable text in dimensions as it is often not visible at all (I have tried to change size of text, model scale - with millimeters template it does not help)
Other annotations would be nice t have but not that critical.
some solution for keeping track of PDFs would be great as well (usually issued documents are …
Speckle should also access the 2d sheet and drawing info in the Revit model. This would include all the 2/3d model and annotation geometry is placed in the model plans, sections and elevations, dimensions and annotations
suspect that if you ask anyone who is involved in detailed design and production information… the 2d ‘drawing’ information is a firm requirements.
All BIM apps like Revit, ArchiCAD etc all rely on providing large amounts of additional 2d information that is not in the 3d model…
