Transfer 2D Drawing From Revit Or AutoCAD into Speckle
Hello
Is there any solution to transfer 2D drawings from AutoCAD or Revit to Speckle?
2D elements are certainly supported from AutoCAD to Speckle, if you are referring to Paperspace transfer, I suspect you might be if you are referring to Revit drawings, this is not on the immediate roadmap for us, but if you take a look around, others are suggesting this and seeking your vote in support of their ideas:
