Thank you for seeking help! Our friendly community is here to assist you.
The speckle plug in for RHino does not seem to load. I have uninstalled and reinstalled it. Version 2.18.2. I also tried the previous version and it did not work. Anyone else facing this issue and have a solution?
Rhino 8 will only work with Speckle >=2.19 (currently available in Manager with the Show Pre-releases toggle) and Rhino >=8.3
Check if the other Speckle connectors installed do not match. It is best if the versions align—particularly between Rhino and Grasshopper but generally all of Speckle connectors. If the Manager shows this:
It might be good to check that everything is version-aligned.
If you have installed Speckle connectors in the past as an admin account, you may want to do additional cleanup, so if you uninstall and reinstall, we should take care of that.
Thanks Jonathon. I am only running Speckle for Rhino. I used to have Speck for Blender, but uninstalled it as the versions did not align and I wanted to trouble-shoot if that was the issue. I still get the error.
I am the admin so that should not be an issue. Should I check for unwanted files in the appdata folder?
I also get this when uninstalling the manager. I wonder if I need to uninstall and delete everything Speckle related, then start fresh. If that seems like the right method, can you let me know from where else I should be removing files?
