Hi again @jonathon
So I tried and install the manager (which seems to be legacy) and installed both Rhino and Grasshopper connectors. When i launch Rhino, i have nothing in the Speckle popup (when i try and move it it explicitely specifies 'Speckle' container is empty
I then tried to remove Grasshopper connector, and tried to manually install plugin as specified here, but this doesn’t change a thing.
Plus when i try to open an old definition, it says that:
and it blocks the opening of the definition.
When i create an empty GH file and try to create a new Accounts component, here’s what it shows:
Finally, when i click Close it does create the component but with no possible account
even if i seem to be properly logged in the manager:
I tried to uninstall, reinstall everything but it seems there’s an issue with the link between the manager and my session, and Rhino connector.
What can i do to unblock the situation?
Thanks in advance
