Grasshopper Load Error
Hi, suddenly my Speckle stopped working in Grasshopper and Rhino and I receive the following error in Grasshopper when trying to use the Accounts component. The window in Rhino also does not load and is just white space. I am using the 2.25.1 connectors from the Speckle Manager.
Does anyone have any tips?
Hey Matthew,
This is most likely due to a dll conflict for the SQLLite library - did you install any other GH or Rhino plugins recently?
Hi Mateo, i found the culprit - it was Tunny: Tunny | Food4Rhino
Sounds fishy! Glad it’s solved :slight_smile:
Hi @mtam
The Speckle team contacted me and created a Tunny that I believe fixed the cause. I will send you a corrected version if needed.
