For anyone having a similar issue, we’ve found a workaround:
- Install the Rhino Connector
- Open Rhino (it will show the error dialog)
- Drag the file
SpeckleConnectorRhino.rhpfrom the folder%appdata%\McNeel\Rhinoceros\7.0\Plug-ins\SpeckleRhino2 (8dd5f30b-a13d-4a24-abdc-3e05c8c87143)\onto the Rhino window - This might take a few seconds, as it triggers a manual installation of the plugin
- The plugin should now be working
PS 1
Ensure that the Plugin is enabled in the Rhino Options
PS 2
The path above can be easily copy-pasted in your Windows Explorer window
