My Grasshopper (and Rhino) crashes very often when it contains Speckle components (no issue otherwise). It happens eighter during Send/Receive (I use the simple Send/Receive componenets - the blue ones - and no automatic sync is activated), or when copying components (any componenets) between files. I use a local speckle server. The problem appears for my collagues too. Do anyone have similar experience? Any idea for the cause or the solution?
HI @reka! Sorry for the late reply, I left this message unsent
Welcome to our community! Feel free to Introduce yourself 🙆 to all other members if you wish.
As for the problem, thanks for reporting this! I’ve managed to reproduce the issue if installing while already having an existing GH installation. Seems like the installer was not properly replacing all the files.
We released version 2.5.2 for GH that should fix the issue for you, let us know if you have any troubles with that. You should see it in your Speckle Manager already
