Hi!
is it possible to attach parameters to my Speckle objects in Grasshopper, without having to use the Speckle Revit components? Bc using those I need alot more inputs like family, family type, level, etc.
Thanks,
Laurin
Hi!
Thanks,
Laurin
Hi @Laurin,
Could you explain a bit more your use-case for this? By parameters
you mean Revit compatible parameters
, or just âmetadata attached to an objectâ?
If youâre targeting Revit, our general suggestion is to use the Speckle Revit components to create elements in your Revit Document. You can always input a fake family name and type and Revit connector will pick the first one available for that element.
Most of these inputs arenât optional because Revit does require them to correctly create the elements, so thereâs little we can do on this side.
If youâre aim us to add or update parameters on an element that already exists in the Revit doc, then I would suggest you use the ParameterUpdater
node for that, which requires way less info to input (but does require you to send the elements from Revit to GH to obtain their elementId
Anyway, do let us know a bit more about how youâre aiming to use Speckle so we can have the whole picture. Weâll be happy to revise some of the decisions weâve made in the past if it makes sense to improve the product!
Thanks for reaching out!
Hi @AlanRynne,
thanks for your answer. In this case i am actually not interested in sending the elements to Revit. I just want to visualize my Rhino/Grasshopper model in Notion or Powerpoint.
So what I am asking for is if I can attach information (Speckle parameters) to the Speckle objects such as a Column as you can see in the picture below.
Well, you can extend a geometry with key/value pairs. Here is an example:
I hope this helps. Let me know if it doesnât.
Yes, that is what I was looking for!
It would be great to explain that a bit more in detail in the documention if other people are looking for that in the future. I couldnât find or didnât understand it here: Grasshopper | Speckle Docs
Thank you for your help
Yeah, we are aware. We will refactor our docs in the coming months and weâll include it in the new docsđ.
