You don’t need to worry about the bbox property. It is auto generated.
afaik, one key can only have one value. If you want to store two values, then you can create a speckle object in which you can store multiple key value pairs.
I’ll look into your code and let you know.
Yes. When sending from Grasshopper, we are sending some auto-generated parameters. Similar to bbox.
My goal is that I am trying to make one workflow from Gh to PowerBI by using Speckle.
There is no Rhino/GH dash in speckle yet.
So I thought if I can make speckle objects in GH with parameters, I can use it in the Power BI as your video (Visualizing Room Data in Power BI - YouTube)
In the video, it is important to have correct parameters.
