resolved: I have manually created a folder with the name “speckle” in the “extensions” directory of archicad 27 (Spanish) and inside I have copied the speckle APX. I restarted the PC and the interface started.
Thanks for sharing how you solved it @jonabatero . We encourage you to share how you are using Speckle. Don’t hesitate to ask for help if you have any other queries.
Hello. I have the same problem in 26 an 27 INT. The folder solution doesn’t work for me.
Tried dowloading older versions and also newest pre-release, nothing seems to work.
please help
