i need help in this error when sending by speckle connector on revit 2024.1
speckle.core.transports .transportException - RemoteTransport transport failed
Hi @Hassan_Al_Emary ,
it’s hard to tell what’s happening without more information. Could you share a small, sample Revit model replicating the issue? Any more details on what you are trying to achieve would be great.
Thanks @Hassan_Al_Emary which version of the Speckle Connector for Revit do you have installed?
Which Speckle server are you attempting a send to, and is this a personal PC or operating behind a network/vpn/firewall etc.
@Hassan_Al_Emary, another thought - can you confirm that if sending only a smaller selection of elements then you don’t have the same problem?
Or if you send exactly the same content multiple times, does it succeed eventually?
We believe this issue is resolved.
