Revit2024 connector - SendCommand failed - RemoteTransport transport failed
Hi Speckle team,
I’m failing to upload a file that previously has worked fine.
It stalls during upload when selecting “everything”, but when selecting walls as category it works fine.
SpeckleCoreLog20240614.txt (3.6 MB)
Similar threads with 2023 connector:
Debugging… Is there a max count, a timeout or anything else?
Categories [Everything] = Fails
Categories [Walls, Windows, Rooms, Roofs, Floors] = Fails
Categories [Rooms] = Works
Categories [Roofs] = Works
Categories [Windows] = Works
Categories [Floors] = Works
Categories [Walls] = Works (1st attempt) Failing (2nd attempt) Working (3rd attempt)
Hey @Sonderwoods ,
It is indeed most likely correlated with those past reports; we’re actively working on a resolution and hope to have a fix out early next week.
We’ll keep you posted!
@Sonderwoods We believe this issue is resolved.
