Hi all,
I see some posts about the Speckle visual staying blank, but all with a warning or a lot of data.
I have a simple box from Grasshopper that I want to show in PowerBI (simple test before testing some heavy models). But the Speckle visual stays blank and nothing is coming up on the screen. What could be wrong?
The stream I use to test is:
8
Can anyone help me?
Sierd
jonathon
(Jonathon)
22 October 2024 08:05
2
If the project is already in Link Shared status, try passing the box through a Brep component before sending it to Speckle.
Hi jonathon,
I make a Brep from the box but it hange nothing.
In powerBI my screen will be blank
jonathon
(Jonathon)
22 October 2024 12:25
4
Is the project set as Link Shared or Private?
It is linkend shared, otherwise I could not share it in the link above.
jonathon
(Jonathon)
22 October 2024 14:21
6
I cannot replicate your issue @Sierd_Tilma
Cube.pbix (951.7 KB)
Try populating the colorby and tooltip fields
I see that you use the Speckle powerBI-visual 2.20.0 where can I download that version I only find this link: Release 2.19.0 · specklesystems/speckle-powerbi-visuals · GitHub
jonathon
(Jonathon)
22 October 2024 14:34
8
Rather than needing to install from Github, we make it easier for you and it is now installable from Speckle Manager
[power-bi-connector-now-available-from-manager-google-docs]
Hello @Community !
Power BI Data Connector can now be installed directly from the Manager for Speckle ! This marks a significant milestone as we are getting closer to the stable release of our Power BI connector.
Important⚠️:
This installer is only for the Data Connector. You still need to download the 3D Visual from the Github repository .
Previously, installing the connector involved downloading it from our GitHu…
I dont get de visual from the speckle manager.
The post you linked say the same. You still need to download the 3d visual from the Github repository. But there you can only find version 2.19.0.
so I do not understand wat I do wrong
jonathon
(Jonathon)
22 October 2024 16:12
10
The visual and the data connector are now bundled in one install since 2.20.0
system
(system)
Closed
20 April 2025 16:12
11
