We have been busy working on the latest updates and the 2.17 Release Candidate is ready for community testing. If you donât feel adventurous, stick with the current stable 2.16 version for uninterrupted project work. Official stable 2.17 release will follow after community testing later this month.
How to test?
Installing the release candidate is easy.
Open the Speckle Manager and find your favourite Connector.
From the menu (3 dots), choose âAvailable versionsâ, and make sure that the âShow pre-releasesâ toggle is on.
Install the 2.17.0-rc .
The 2.17 version is also recommended for testing the new frontend, give it a go at app.speckle.systems .
If you wish to revert back, click the install button for the 2.16 version in the âAvailable versionsâ.
How to give feedback?
Post your feedback in this thread, and we will take it from there.
The new RC is packed with features and improvements, so give it a whirl and let us know what you think.
Archicad
Archicad levels can be received to Revit now
Layer property has been added to Archicad objects
Archicad commits are structured in collections to align with other Speckle Connectors
Added support for grids
ETABS
More granular filtering of analysis results on send
Improved handling of openings when receiving models from Revit
Bug fix when receiving structural materials
Rhino
Added support for grids on receive
Improved handling of materials with no name on receive
AutoCAD
Revit
Improved support for rebar on send
Floors and ceilings with complex boundary curves are now reliably received
Added level of detail setting when sending
QGIS
Resolving dependencies error that have caused plugin failure on creating Streams/Branches and accessing account.
@gjordanp - where are you attempting to view the streams from? Is it in your browser at https://app.speckle.systems, or in a connector, or a custom server deployment?
I used this version to send analysis results from Etabs to Revit but I wasnât successful. Did I do something wrong or itâs still not fully functional in this version ?
