Hi friends
I have a problem in Rhino when I try to make a server to send my files to Revit
It has an error message
“The graphql request failed without a graphql response”
Thanks for helping
Hi friends
Thanks for helping
Hey there,
Welcome to the forum, feel free to Introduce yourself
if you’d like!
The error seems due to firewall/vpn issues, can you send us your logs in %appdata%/Speckle/Logs?
Also make sure to unblock these URLS:
Hi
Thanks for your response, I introduce myself
I have speckle in Revit2024 and It is correct but It does not work correctly in Rhino7.
I turned off the firewall from Windows 11 security and now, Rhino makes stream correctly.
I don’t know that for each time in Rhino,
Do I have to turn it off?
Thanks.
You may need to whitelist certain addresses/ports as described in the readme rather than turn off the firewall wholesale.
Logs please! ![]()
Just copy-past the above in windows explorer and it’ll take you to the right folder.
LOG.rar (121.7 KB)
Thanks, ![]()
Thanks, Yes I should add the addresses to my firewall.
Thanks! I can see some requests are failing but others work, can you try sending a very small model? Or just some geometry?
You’re welcome,
Yes, I sent a sample model of Rhino, Of course, I converted an .IGS to Rhino for importing in Revit.
A plate-c-ibox-basin.3dm (8.1 MB)
6703-94-80CP_style.SLDPRT (1.2 MB)
6777-AD-80CP_style.igs (198.0 KB)
Hi, I´m having the same problem, and it appers the text, because I dont know if the size of the model making the error how I can
How I can do that? What file are you talking about?
Welcome to Speckle @josephEx , any help you can give us to diagnose your problem is golden.
We can start with some Logs output: Rhino Error, The graphql request failed without a graphql response - #5 by teocomi
But more generally, as we’ve asked above, any insight into the environment in which you are running Rhino and Speckle is useful, such as a VPN, behind firewalls, corporate IT network, etc.
SpeckleCoreLog20240518_003.txt (836 Bytes)
SpeckleCoreLog20240518_004.txt (5.8 KB)
SpeckleCoreLog20240519.txt (418 Bytes)
SpeckleCoreLog20240518_001.txt (142.4 KB)
SpeckleCoreLog20240518_002.txt (47.1 KB)
Thanks @jonathon, the main problem is that i try to export a big file from rhino to blender and aparently is no workind when I wanto to send from rhino to Speckle but if I tryit with revit works awesome
