Hi Speckle Team,
I am having trouble with sending analytical wall surfaces from Revit 2023 to ETABS. Walls with openings are skipped in the ETABS receive step. See snips below:
Analytical surfaces sent from Revit:
Received in ETABS
System:
Revit: 2023
Revit Connector: 2.13.3
ETABS Connector: 2.13.3
Am I missing something in the workflow? I believe openings in analytical surfaces are now supported with Revit 2023?
Cheers!
Björn
cc: @AlexHofbeck
We also tried it with the newest rc version of the connectors with the same result
jonathon
(jonathon@stardotbmp.com)
May 25, 2023, 10:18am
3
Is this something that used to work for you and no longer does?
Hi @jonathon
Unfortunately not. This dates back to this post: ETabs 20.3 and Revit 2022 Interoperability issue - #9 by bjoernsteinhagen . However, we thought with Revit 2023 and the latest connectors, walls with openings would be included.
teocomi
(Matteo Cominetti)
May 25, 2023, 2:15pm
5
@bjoernsteinhagen This must have flown under the radar; I’ve added it to our backlog and we’ll keep you posted on the progress!
