Revit could not complete external command Serilog.LoggerConfiguration
Trying to export out of Revit to Speckel and when I select even just 1 object and click the blue box I get this error. Any help would be greatly apprecieated.
Revit could not complete the external command. Contact the provider for
assistance. Information they provided to Revit about their identity: Speckle
Empowering your design and construction data. For any problems, visit our
community forum https://speckle.community.
Revit encountered a System.MissingMethodException: Method not found:
Serilog.Configuration.LoggerSink Configuration. Conditional(System.Funci2 < Serilog.Events.LogEv.
System.Action`1 < Serilog.Configuration.LoggerSinkConfiguration>)".
at Serilog.SeqloggerConfigurationExtensions.Seq(LoggerSinkConfiguration
loggerSinkConfiguration, String serverUrl, LogEventLevel restricted ToMinimumlevel, Int32
batchPostingLimit, Nullable'1 period, String apikey, String bufferBaseFilename, Nullable1
bufferSizeLimitBytes, Nullable'1 eventBodyLimitBytes, LogginglevelSwitch controlLevelSwitch
HttpMessageHandler messageHandler, Nullable 1 retainedlnvalidPayloadsLimitBytes, Int32
queueSizelimit)
at Speckle.Core.Logging.Specklelog.CreateConfiguredLogger(String hostApplicationName
String hostApplicationVersion, SpecklelogConfiguration logConfiguration)
at Speckle.Core.Logging.Specklelog.lnitialize(String hostApplicationName, String
at Speckle Core.Logging.Specklelog.get_Logger0
at Speckle.ConnectorRevit.Entry.SpeckleRevitCommand.Execute(ExternalCommandData
commandData, String& message, ElementSet elements)
at apiManagedExecuteCommand (AString* assemblyName, AString* className, AString*
vendorDescription, MFCAPp* pMFCApp, DBView* pDBView, AString* message,
Set<ElementidI,std:less <Elementld>I,tnallc< Elementld> >^ ids,
Map<AStringI,AString\,std:less< AString> I, tnallc< std:pair< AString const \AString>
data, AString' exceptionName, AString" exceptionMessage)
Hey @B.Kaiser ,
This is most definitely due to a conflict with another Revit or Dynamo plugin, please see these steps on how to fix it: "Revit cannot run the external application Speckle 2 for Revit" :( - #2 by teocomi
Some other users had the same problem with the VIM plugin.
@teocomi it appears is if it was PnIDmodeler.dll causing issues with mine. It opens now thanks for your help with this!
