jonathon
(Jonathon)
29 October 2022 05:47
2
Oops. That’s not good.
To start trying to resolve this for you, can I ask how you’ve installed the Speckle for Blender plug-in? Have you used the Manager or by other means?
Yep, I installed the Blender plug in through the manager. Could it be because I’m not using the latest version of blender or speckle?
gokermu
(Mucahit Bilal GOKER)
31 October 2022 04:32
4
I think it should work for Blender 2.93 anyways. I’ll try to reproduce this on my end and see what’s the reason behind it.
Just to be on the safe side, did you try restarting Blender and see if it helps?
gokermu
9 November 2022 09:41
5
Ok, looks like we’ve changed some things and it doesn’t work on 2.93 anymore. I created an issue and we’ll tackle this asap. In the meantime you can install 2.7 release. I tested it and it worked on my end.
I’ll let you know once we fix this issue.
opened 09:39AM - 09 Nov 22 UTC
bug
p1
## Description
Related to this [thread](https://speckle.community/t/question-… how-can-i-resolve-this-blender-error-when-trying-to-install-speckle/3947).
The latest version of the Speckle connector not working in Blender 2.93. I guess it's due to recent changes. I installed version 2.7 of the connector and it worked fine.
Blender 2.93 is from the LTS series. That's why it's especially important that we support this version.
## Expected Behaviour
Latest release should work just fine.
## Steps to reproduce
1. Install the latest Blender connector via Manager.
2. Open Blender and go to Add-ons settings.
3. Try to enable Speckle connector. You’ll face an error.
## Screenshots
Jedd
(Jedd Morgan)
14 November 2022 19:37
6
Hi @Samantha_T
I’ve just pushed a fix for our connector on Blender 2.93.
You should see a new version 2.9.1
of the connector now on manager.
Hopefully this fixes all your issues.
see related discussion
gokermu
Split this topic
18 January 2024 10:31
7
