Hi @jonathon !
I follow the step but Im facing this error when I’m trying to re-authenticate:
Is this with the latest version of the Powerbi connector?
Yes, fresh from this morning ![]()
The error detail:
Feedback Type:
Frown (Error)
Timestamp:
2025-03-13T15:59:25.7583293Z
Local Time:
2025-03-13T11:59:25.7583293-04:00
Session ID:
01c27080-2e5d-48d1-a987-5fd8a9ef7582
Release:
February 2025
Product Version:
2.140.1476.0 (25.02)+e8c6a85d1d09735c5c055c3244a60ff4076cd2cf (x64)
Error Message:
Value cannot be null.
Parameter name: uriString
Stack Trace:
System.ArgumentNullException
at System.Uri..ctor(String uriString, UriKind uriKind)
at System.UriBuilder..ctor(String uri)
at Microsoft.Mashup.Client.UI.Extensions.Windows.SystemBrowserOAuthDialog.WrapUrlForPowerBiOAuthRedirect(Uri authorizationUri, UriBuilder redirectUriBuilder)
at Microsoft.Mashup.Client.UI.Extensions.Windows.SystemBrowserOAuthDialog.Authorize(Uri logoutUri, Uri authorizationUri)
at Microsoft.Mashup.Client.UI.Shared.OAuthManager.<OpenOAuthDialog>d__11.MoveNext()
Stack Trace Message:
Invocation Stack Trace:
at Microsoft.Mashup.Host.Document.ExceptionExtensions.GetCurrentInvocationStackTrace()
at Microsoft.Mashup.Client.UI.Shared.StackTraceInfo..ctor(String exceptionStackTrace, String invocationStackTrace, String exceptionMessage)
at Microsoft.PowerBI.Client.Windows.Telemetry.PowerBIUserFeedbackServices.GetStackTraceInfo(Exception e)
at Microsoft.PowerBI.Client.Windows.Telemetry.PowerBIUserFeedbackServices.ReportException(IWindowHandle activeWindow, IUIHost uiHost, FeedbackPackageInfo feedbackPackageInfo, Exception e, Boolean useGDICapture)
at Microsoft.Mashup.Client.UI.Shared.UnexpectedExceptionHandler.<>c__DisplayClass14_0.<HandleException>b__0()
at Microsoft.Mashup.Client.UI.Shared.UnexpectedExceptionHandler.HandleException(Exception e)
at System.Runtime.CompilerServices.AsyncTaskMethodBuilder`1.Start[TStateMachine](TStateMachine& stateMachine)
at Microsoft.Mashup.Client.UI.Shared.OAuthManager.OpenOAuthDialog(IWindowHandle parentWindowHandle, ITelemetryService telemetryService, String resourceKind, String accessToken, String resourceUrl)
at Microsoft.Mashup.Client.UI.Shared.Ux.FloatingDialog.ChallengeFloatingDialogBase.<OpenOAuthDialogAsync>d__29.MoveNext()
at System.Runtime.CompilerServices.AsyncTaskMethodBuilder.Start[TStateMachine](TStateMachine& stateMachine)
at Microsoft.Mashup.Client.UI.Shared.Ux.FloatingDialog.ChallengeFloatingDialogBase.OpenOAuthDialogAsync(IDialog parentDialog, ILegacyUIHost uiHost, IExceptionHandler exceptionHandler, IJsHostedScript jsHostedScript, IInteractiveMsalProvider msalProvider, ITelemetryService telemetryService, String resourceKind, String logoutAccessToken, String dataUrl)
at Microsoft.Mashup.Client.UI.Shared.Ux.FloatingDialog.ChallengeFloatingDialogBase.OnOpenOAuthDialog(String resourceKind, String logoutAccessToken, String dataUrl)
at System.RuntimeMethodHandle.InvokeMethod(Object target, Object[] arguments, Signature sig, Boolean constructor)
at System.Reflection.RuntimeMethodInfo.UnsafeInvokeInternal(Object obj, Object[] parameters, Object[] arguments)
at System.Reflection.RuntimeMethodInfo.Invoke(Object obj, BindingFlags invokeAttr, Binder binder, Object[] parameters, CultureInfo culture)
at Microsoft.Mashup.Client.UI.Shared.JsExportWrapper.<>c__DisplayClass13_0.<InvokeMember>b__0()
at Microsoft.Mashup.Client.UI.Windows.JsErrorHandler.WrapInvokeHost(Func`1 invokeHost)
at System.Windows.Forms.UnsafeNativeMethods.DispatchMessageW(MSG& msg)
at System.Windows.Forms.Application.ComponentManager.System.Windows.Forms.UnsafeNativeMethods.IMsoComponentManager.FPushMessageLoop(IntPtr dwComponentID, Int32 reason, Int32 pvLoopData)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoopInner(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Application.ThreadContext.RunMessageLoop(Int32 reason, ApplicationContext context)
at System.Windows.Forms.Form.ShowDialog(IWin32Window owner)
at Microsoft.Mashup.Client.UI.Windows.DialogWindowBase.ShowModal(IWindowHandle windowHandle)
at Microsoft.Mashup.Client.UI.Shared.WebDialogs.WebDialog.<>n__0(IWindowHandle owner)
at Microsoft.Mashup.Client.UI.Shared.WindowManager.ShowModal[T](T dialog, Func`1 showModalFunction)
at Microsoft.Mashup.Client.UI.Shared.Ux.CredentialsChallengeResolver.ShowResolveDialog(IWindowHandle owner, IUIHost uiHost)
at Microsoft.Mashup.Client.UI.Shared.Ux.FloatingDialog.BuilderDialog.Js_HandleCredentialChallengeAndCloseBuilder(String dialogData)
at System.Windows.Forms.UnsafeNativeMethods.IDispatch.Invoke(Int32 dispIdMember, Guid& riid, Int32 lcid, Int32 dwFlags, tagDISPPARAMS pDispParams, Object[] pVarResult, tagEXCEPINFO pExcepInfo, IntPtr[] pArgErr)
at System.Windows.Forms.HtmlDocument.InvokeScript(String scriptName, Object[] args)
at Microsoft.Mashup.Client.UI.Windows.JsErrorHandler.WrapInvokeScript(Func`1 invokeScript)
at Microsoft.Mashup.Client.UI.Shared.AjaxHost.AjaxHandler.<>c__DisplayClass11_0.<OnProcessAjaxAsync>b__0()
at Microsoft.Mashup.Host.Document.SynchronizationContextExtensions.<>c__DisplayClass2_0.<SendAndMarshalExceptions>b__0(Object null)
at System.Delegate.DynamicInvokeImpl(Object[] args)
at System.Windows.Forms.Control.InvokeMarshaledCallbackDo(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbackHelper(Object obj)
at System.Threading.ExecutionContext.RunInternal(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state, Boolean preserveSyncCtx)
at System.Threading.ExecutionContext.Run(ExecutionContext executionContext, ContextCallback callback, Object state)
at System.Windows.Forms.Control.InvokeMarshaledCallback(ThreadMethodEntry tme)
at System.Windows.Forms.Control.InvokeMarshaledCallbacks()
at System.Windows.Forms.Control.WndProc(Message& m)
at System.Windows.Forms.NativeWindow.Callback(IntPtr hWnd, Int32 msg, IntPtr wparam, IntPtr lparam)
at Microsoft.Mashup.Client.UI.Shared.WindowManager.ShowModalWithInitialReentrancyLock(FloatingDialog floatingDialog, ILegacyUIHost uiHost, Func`1 showModalFunction)
at Microsoft.Mashup.Client.UI.Shared.DataImporter.ShowBuilderDialog(PackageReference packageReference, FormulaPath formulaPath, FormulaPartInfo formulaPartInfo, Query query, Action`2 successCallback, Action failureCallback, Boolean isNewQuery, Boolean isFromEditor)
at Microsoft.Mashup.Client.UI.Shared.DataImporter.ResolveQuerySettings(Query query, Action`2 successCallback, Action failureCallback, ResolutionSetting resolutionSetting, Boolean isNewQuery, Boolean isFromEditor)
at Microsoft.Mashup.Client.UI.Shared.DataImporter.ResolveQuerySettings(Query query, SourceFormula addedFormula, Boolean isNewQuery, Boolean isFromEditor)
at Microsoft.Mashup.Client.UI.Shared.DataImporter.TryAddSource(String sourceID, Nullable`1 targetQueryGroupId, Query& newQuery)
at Microsoft.PowerBI.Client.Windows.PowerBIDataImporter.TryAddSource(String sourceID, Nullable`1 targetQueryGroupId, Query& newQuery)
at Microsoft.Mashup.Client.UI.Shared.ConnectHelper.Connect(IWindowHandle owner, IDataSourceTemplateProvider dataSourceTemplateProvider, ILegacyUIHost uiHost, ITelemetryService telemetryService, DataImporter dataImporter, CommandUIControlBase commandUIControl, String sourceId, Nullable`1 targetQueryGroupId)
at Microsoft.PowerBI.Client.Windows.Services.QueriesEditorWindowManager.GetData(PowerBIDataImporter dataImporter, String sourceId, Nullable`1 targetQueryGroupId, IDataSourceTemplateProvider dataSourceTemplateProvider, IWindowHandle ownerWindow)
at Microsoft.PowerBI.Client.Windows.Commands.ApplicationCommands.DataImportCommands.<Connect>d__52.MoveNext()
at Microsoft.PowerBI.Client.Windows.Commands.ApplicationCommands.DataImportCommands.Connect(IPowerBIWindowService windowService, IExceptionHandler exceptionHandler, ConnectParameters parameters)
at Microsoft.PowerBI.Client.Windows.IExceptionHandlerExtensions.<HandleAwaitableAsyncExceptions>d__1.MoveNext()
at Microsoft.PowerBI.Client.Windows.IExceptionHandlerExtensions.HandleAwaitableAsyncExceptions(IExceptionHandler exceptionHandler, Func`1 asyncFunc)
at Microsoft.PowerBI.Client.Windows.Commands.CompositeCommand`1.Execute(ICommand command, Object parameter)
at Microsoft.Practices.Prism.Commands.CompositeCommand.Execute(Object parameter)
at Microsoft.PowerBI.Client.Windows.Commands.CompositeCommand`1.Execute(T parameter)
at Microsoft.PowerBI.Client.Windows.PowerBIDataSourceTemplateProvider.ConnectInternal(String formulaId, Nullable`1 targetQueryGroupId)
at Microsoft.Mashup.Host.Document.DataSourceTemplateProvider.Connect(String formulaId, Nullable`1 targetQueryGroupId)
at Microsoft.Mashup.Client.UI.Shared.Ux.FloatingDialog.SimpleDialog.DataSourceGalleryDialog.<>c__DisplayClass12_0.<ConnectToDataSource>b__0()
at Microsoft.Mashup.Host.Document.ExceptionHandlerExtensions.HandleExceptions(IExceptionHandler exceptionHandler, Action action)
at Microsoft.PowerBI.Client.AppModule.<>c__DisplayClass4_0.<Run>b__0()
at Microsoft.PowerBI.Client.Windows.IExceptionHandlerExtensions.<>c__DisplayClass3_0.<HandleExceptionsWithNestedTasks>b__0()
at Microsoft.PowerBI.Client.AppModule.Run()
at Microsoft.PowerBI.Client.Program.RunApplicationFlow(String[] args, IPowerBIRootTrace trace)
at Microsoft.PowerBI.Client.Program.Main(String[] args)
PowerBINonFatalError:
{"AppName":"PBIDesktop","AppVersion":"2.140.1476.0","ModuleName":"Microsoft.Mashup.Client.UI.Extension.dll","Component":"Microsoft.Mashup.Client.UI.Extensions.Windows.SystemBrowserOAuthDialog","Error":"System.ArgumentNullException","MethodDef":"WrapUrlForPowerBiOAuthRedirect","ErrorOffset":"26","ErrorCode":""}
OS Version:
Microsoft Windows NT 10.0.26100.0 (x64 en-GB)
CLR Version:
4.8 or later [Release Number = 533320]
Peak Virtual Memory:
71.7 GB
Private Memory:
1.03 GB
Peak Working Set:
1.32 GB
IE Version:
11.1882.26100.0
User ID:
b98033c5-8a2f-4cac-aee6-045fce9b7bde
Workbook Package Info:
1* - en-CA, Query Groups: 0, fastCombine: Disabled, runBackgroundAnalysis: False.
Telemetry Enabled:
True
Snapshot Trace Logs:
C:\Users\dave.otis\Microsoft\Power BI Desktop Store App\FrownSnapShotbcea4d1e-debc-4cc7-a9fb-ab4af589c24f.zip
Model Default Mode:
Empty
Model Version:
PowerBI_V3
Performance Trace Logs:
C:\Users\dave.otis\Microsoft\Power BI Desktop Store App\PerformanceTraces.zip
Enabled Preview Features:
PBI_sparklines
PBI_scorecardVisual
PBI_fieldParametersSuperSwitch
PBI_setLabelOnExportPdf
PBI_oneDriveSave
PBI_oneDriveShare
PBI_useModernPublishDialogs
PBI_gitIntegration
PBI_tmdlInDataset
PBI_directLakeRemoteModeling
PBI_newCard
PBI_buttonSlicerAuthoring
PBI_EimLessElevatedUser
PBI_mobileAutoReportLayout
PBI_daxInlineCopilot
PBI_aiNarrativesVisual
PBI_generateMeasureDescriptionsButton
PBI_visualCalculationsAuthoring
PBI_desktopReportAuthoringCopilot
Disabled Preview Features:
PBI_snowflakeAdbcVersionEnabled
PBI_shapeMapVisualEnabled
PBI_SpanishLinguisticsEnabled
PBI_qnaLiveConnect
PBI_metricsArtifactsOnDesktop
PBI_b2bExternalDatasetSharing
PBI_enhancedTooltips
PBI_onObject
PBI_odspSaveBackgroundUpload
PBI_modernOfficeFilePicker
PBI_publishDialogsSupportSubfolders
PBI_enhancedReportFormat
PBI_advancedSlicerTypeList
PBI_textSlicer
PBI_qnaImproveLsdlCopilot
PBI_tmdlViewToggle
PBI_UserInstalledVerticaODBCDriver
Disabled DirectQuery Options:
TreatHanaAsRelationalSource
Cloud:
GlobalCloud
PowerBIUserFeedbackServices_IsReported:
True
DPI Scale:
125%
Supported Services:
Power BI
Formulas:
section Section1;
shared Query1 = let
Source = Speckle.GetByUrl("https://app.speckle.systems/projects/10998ad4ad/models/19585f4f58")
in
Source;
Can you resolve this problem? If you can, please help me. Thank you so much
@Trung535 , i don’t know if you ask me the question but i’m still have the problem.
@jonathon it’s the same problem that @ashinde_TYL faced but when i’m looking at her screenshot, it’s not the new version of the visual. I don’t know about is connector.
This still requires a solution but as a workaround, can you try setting Personal Access Token as the authentication method. You can get your PAT from Log in | Speckle.
And paste it into Private Project > Personal Access Token.
@gokermu I just tried it but no success ![]()
Same error message “Access to the resource is forbidden”.
Did you try clearing permissions prior to that?
- Go to File > Options and settings > Data source settings.
- Select Global permissions.
- Select https://app.speckle.systems and select Clear Permissions
Hi @gokermu ,
Yes I did. See the attach video
@oguzhan, @Dave_O has followed all our troubleshooting steps, and the link to the project is not private and has had no success.
There is a separate thread with the same outcomes also with a screen recording not in a solved thread.
https://speckle.community/t/how-to-view-model-in-powerbi/17088/8?u=jonathon
12 posts were split to a new topic: Access to resource is forbidden
Thanks @gokermu ,
I will give it a try later today!
This is my PowerBI version:
You are using the latest version of Power BI. We encountered some issues that were resolved by updating Power BI, so I wanted to confirm that you have the most recent version.
I hope updating the data gateway will solve the issue. Please ensure you have admin rights to the data gateway. If this doesn’t resolve the problem, we have two additional options to try as a last resort.
Option 1
You can clear the contents of the following folders:
For the Windows Store-installed app:
Delete the contents of this folder:
%userprofile%\Microsoft\Power BI Desktop Store App\ExtensionCache
For the Power BI Desktop installed using the offline/web installer:
C:\Users\<username>\AppData\Local\Microsoft\Power BI Desktop\ExtensionCache
Option 2
Clear the directory:
C:\Users\<username>\AppData\Local\Microsoft\Power BI Desktop and then try again.
If you are concerned that this may delete too much data, you can make a backup of all the folders in that directory by copying them to a different location before clearing it.
Hi @gokermu ,
I install the personal gateway but it doesn’t change anything. I read a little bit on how to use it and I see that to apply the gateway, I need to be able to connect to my dataset and then apply the gateway. Is the problem because I can’t connect to my dataset. Do I need to publish the dashboard to the powerbi service and then apply the gateway? Speckle is aprove in the data connectors (sorry for the Autodesk one):
Haha, don’t be sorry. Tbh, i don’t know much about the personal gateway as I didn’t have any issues myself.
Did you try my other 2 suggestions?
@gokermu yes I tried it and some error message.
Thank you, @Dave_O, for taking the time to help debug this issue together.
For others experiencing the same problem, @here, here’s how we resolved it in Dave’s case:
- Go to File > Options and settings > Options.
- Navigate to the Security tab.
- Under Authentication Browser, uncheck the box for “Use my default web browser.”
This solution seems to resolve the error message: “Value cannot be null. Parameter name: uriString.”
