shuzmm
(Shuwei Z)
November 4, 2022, 2:25am
1
Hi All,
I’ve gotten my webapp to the point where it can now be deployed. But running into another problem, which is getting the authenticated user.
I was following the tutorial here which builds a website in Vuetify, has anyone done this in streamlit?
Creating Your Own App | Speckle Docs
Not quite sure where to go from here so any pointers would be great!!
gokermu
(Mucahit Bilal GOKER)
November 4, 2022, 5:39am
2
Hey @shuzmm ,
@Wassim_Jabi made a streamlit app and afaik figured the authentication part. You can sneak peek into his code. I think below is how he figured it out.
Hi ping me if you need help authenticating to Speckle from Streamlit.
shuzmm
(Shuwei Z)
November 6, 2022, 7:48pm
4
Amazing stuff!! thanks for the assist @Wassim_Jabi will send you a message
tomasmena
(Tomas Mena)
January 16, 2023, 12:48pm
5
Hi everyone;
I´ve been trying to deply a simple streamlit app but I´m getting this authentication error in the streamlit platform:
2023-01-16 12:40:00.598 >>> {"query": "query Server {\n serverInfo {\n version\n }\n}"}
2023-01-16 12:40:01.118 <<< {"data":{"serverInfo":{"version":"2.11.4"}}}
2023-01-16 12:40:01.121 >>> {"query": "query Server {\n serverInfo {\n version\n }\n}"}
2023-01-16 12:40:01.416 <<< {"data":{"serverInfo":{"version":"2.11.4"}}}
2023-01-16 12:40:01.419 >>> {"query": "query User($id: String) {\n user(id: $id) {\n id\n email\n name\n bio\n company\n avatar\n verified\n profiles\n role\n }\n}", "variables": {"id": null}}
2023-01-16 12:40:01.757 <<< {"errors":[{"message":"You do not have the required privileges.","locations":[{"line":2,"column":3}],"path":["user"],"extensions":{"code":"FORBIDDEN"}}],"data":{"user":null}}
2023-01-16 12:40:01.761 >>> {"query": "query User($stream_limit: Int!) {\n user {\n id\n bio\n name\n email\n avatar\n company\n verified\n profiles\n role\n streams(limit: $stream_limit) {\n totalCount\n cursor\n items {\n id\n name\n role\n isPublic\n createdAt\n updatedAt\n description\n commentCount\n favoritesCount\n collaborators {\n id\n name\n role\n }\n }\n }\n }\n}", "variables": {"stream_limit": 10}}
2023-01-16 12:40:02.102 <<< {"errors":[{"message":"You do not have the required privileges.","locations":[{"line":2,"column":3}],"path":["user"],"extensions":{"code":"FORBIDDEN"}}],"data":{"user":null}}
If anyone has some inputs I´ll be be thankful
Best.
Tomás
jonathon
(jonathon@stardotbmp.com)
January 16, 2023, 1:00pm
6
Is stream sharing turned on? Or if not, are you passing a user token?
tomasmena
(Tomas Mena)
January 16, 2023, 1:07pm
7
Hi!
The stream is public and I am passing a user token.
When I launch it from the local host, it works without problem. is when I am deploying it on streamlit that is giving me this error.
gokermu
January 16, 2023, 1:39pm
8
How are you authenticating? Can you share the repo?
AlanRynne
(Alan Rynne)
January 16, 2023, 1:40pm
9
I notice that you have a health check error on your deployed app that is pointing to localhost:8501
still. Not sure if it would be the cause of the issue. Maybe you have to update some value somewhere?
tomasmena
(Tomas Mena)
January 16, 2023, 1:48pm
10
Hi!
I´m authenticating with a token.
here you have the repo.
tomasmena
(Tomas Mena)
January 16, 2023, 2:39pm
12
Finally I generated a new token and it granted me access. Now a new problem, the Iframe doesn´t show up .
gjedlicska
(Gergő Jedlicska)
January 16, 2023, 2:40pm
13
Hey @tomasmena
First things first. You really shouldn’t have your token shared in a public repository, now I (or anyone else a bit more malevolent) can have access to your data. If you want to keep the authentication method wit a token I suggest you use an environment variable to store and retrieve the auth token.
I tried to clone your repo and run the app, but it failed for me too, because the baked in string token is invalid.
The reason why it works locally, is because specklepy
falls back to accounts available on your machine.
jonathon
January 16, 2023, 2:43pm
14
Good, now revoke it and use environment variables instead of inlining in the public code. Does streamlit support that?
So, the next step, is what is the developer console reporting? Is the viewer present in the DOM?
gokermu
15
afaik, streamlit does support environment variable.
tomasmena
(Tomas Mena)
January 16, 2023, 2:48pm
16
The viewer is present on the DOM
jonathon
January 16, 2023, 2:49pm
17
I can see it hasn’t loaded, what does the console log report?
tomasmena
(Tomas Mena)
January 16, 2023, 2:52pm
18
5.1ebf0425.chunk.js:2 Mixed Content: The page at 'https://publicmachinery-winter-garden-main-c6ibzw.streamlit.app/' was loaded over HTTPS, but requested an insecure frame 'http://speckle.xyz/embed?stream=8dd22c09e4&commit=f42a6e31b6&autoload=true'. This request has been blocked; the content must be served over HTTPS.
jonathon
January 16, 2023, 2:53pm
19
If you add an s
to http
for the embed URL?
https://speckle.xyz/embed?stream=8dd22c09e4&commit=f42a6e31b6
tomasmena
(Tomas Mena)
January 16, 2023, 2:58pm
20
It Works!!! thanks a lot for everyone’s patience !
@gjedlicska thanks for the observation… Really important. !
gokermu
January 16, 2023, 3:16pm
21
Hey @tomasmena ,
quick question: why did you authenticate? As far as I see, there is no need for authentication in your case. It is a simple embed viewer, isn’t it?
