hello everybody! i would like to know if there is a way in wich we can create a geometry in rhino an export it into revit to be a floor. it would be a floor with its nodes modified in height. Thanks in advance
Hey @roberto_acon welcome!
Could you clarify what you intend with “modified nodes”?
Do you mean sloped surfaces?
I mean a surface divided in triangles with the points at different heights for revit to read it as a floor with modified subelements in height.
Right.
Someone else here asked something similar. The answer was that it isn’t supported right now but youve definitely been heard
If your’s is a different it’s always good to record any nuance.
yes, it is exactly what I want. thanks
