Edge Visibility in Speckle Viewer
I wanted to ask if there are any plans to include the “edges” feature in the Speckle viewer. I’ve noticed that my architects prefer to see the edges and floor edges (The floor is aligned in a straight line with the mass form). In Revit, this feature is available, but since these are edges, they are not displayed in 3D view in Speckle.
Here Speckle View
Here Revit View
that’s a very pretty model btw :blue_heart:
Hi @Eleron96
Edge display has been an ongoing topic in our dev pipeline for a while now. Currently we’re not displaying them, however making an extension to the viewer that does it, would be doable. If you are using the viewer package in your own app, I could be able to help you with it. If you are running the viewer in the official speckle web app, then this option for customization is not available
The good news is that, regardless of how you are using the viewer, we have recently started the development of an initiative where we will be adding various view modes in the viewer. Several of these view modes rely heavily on edge display, so one way or another I expect that they will be made available for viewing. Will keep you posted!
Cheers
PS: Indeed, that model really is pretty!
@alex @jonathon Thank you very much for your feedback!
Regarding the feature request, thank you for the information! I’m trying to relay only the essential features that the architects are asking for :sweat_smile:
Discussing this in the open @alex, do you think edges mode would imply work on the Connectors side? From a Navisworks perspective, its meshes are extremely faceted, and the difference between hard and soft edges between faces is not rationalised.
Would work on Publish help, or would the viewer implementation likely have all the smarts to resolve this?
Here’s the last documented entry regarding edge generation/display. Last I remember, there are several issues with the edges:
  • Edge data is not available for all speckle objects. So for the ones which don’t we need to generate them ourselves
  • Generating the edges ourselves is an imperfect process, at least using the default mechanism from three.js. It relies on a user defined threshold value, which does not work for all objects the same
  • Generating the edges using the approach above it slow. Too slow for our needs anyway. And speeding this up might not be worth the effort, since you still end up with a result prone to inconsistencies.
Ideally, the viewer would receive the complete and correct edge data from the connectors. However, I’m not entire sure this is actually feasible. Maybe @dimitrie might know why/how.
Just to disambiguate, when we say edges we don’t mean the edges of the geometry we render. We can display those, but that’s not you want. We triangulate all our geometry for real time rendering, so the edges post-triangulation are not the same edges you want to see.
Hi guys,
I wasn’t sure whether to create a new topic or reopen this discussion. Sorry if this wasn’t the best option.
My team and I are implementing Speckle in our project, running it locally, and exporting a Revit model to Speckle. In our structural design methodology, we separate walls into multiple stripped sections and then analyze them to determine their structural viability.
However, when we export the model to Speckle, we end up with a wall that appears as a single continuous piece instead of the segmented parts as they are in Revit.
We thought that adjusting the visibility settings or coloring the edges of the wall might help. Is it possible to do this either on the connector side or in the viewer?
On the left side, you can see a Revit screenshot showing the expected appearance:
Thank you in advance
Hello @Luan_Bregunce,
You can enable edges in the viewer by following these steps:
Shortcut for Rendered+Edges mode is Shift+2
Hi @gokermu ,
thank you for the reply.
Actually, I have already done that, but it’s not exactly what I expected. I was trying to find a way to have each stripped section of the wall with the stencil edge, not just the contour of the whole building.
Hi Guys,
Just to give you guys a feedback, we manage achieve that by creating a new material with a low opacity, that works fine to us.
const renderTree = viewerStore.viewer.getWorldTree().getRenderTree(nodeTree.model.id);
const node = viewerStore.viewer.getWorldTree().findId(nodeTree.model.id);
const rvs = renderTree.getRenderViewsForNode(node[0]);
const materialData = {
      color: 0xa0a0a0,
      opacity: 0.5,
      roughness: 1,
      metalness: 0,
      vertexColors: false,
viewerStore.viewer.getRenderer().setMaterial(rvs, materialData);
@Luan_Bregunce , I understand it now. Unfortunately, it’s a known limitation of how we generate edges on the fly. You can read more about it here: How Speckle Generates Outlines from Geometry Data
@alex is it possible to make edges visible per element?
As per Revit Parts Visualisation In Speckle - #6
0e3cdd8b-7461-46f5-b0da-3358f1c437c4_text
I’ve been thinking a bit about this and I think it’s possible.
massive hype on this topic. it’s pretty much a need for our use. (also raised here)
Hi @ChrisT @Eleron96 @Luan_Bregunce
We’ve just released an update to the viewer’s Pen View Mode which addresses the issues you’ve brought up. :smiley_spockle:
We’d love it if you give it a go and see how it works for you!
Cheers
Hey @alex, amazing! I had a quick look; my first impression was that it looked great. I also see the edges visible on the render with edges; this is pretty much what I imagined. The reactiveness is impressive :D!
Perhaps it’s a separate point, but I imagine it’s related. Can the dimension tools snap to the edges?
We’re glad it’s working nicely for you! :partying_spockle:
As for the measurement tools snapping to the edges, that’s slightly a different story however, we are going to make some updates to the measurement tools and maybe we’ll give snapping to the edges some thought.
Since our edges are screen space and generated on the fly inside a shader it will be extra difficult to “snap” to them. We do have some ideas though, so I’m tempted to say again “Perhaps an arrangement… can be arranged” :smiley:
Cheers
Updates to the measurement tools sound exciting! Are there any sneak preview titbits you can share :innocent:?.
Love the “Perhaps an arrangement… can be arranged”. Edge snapping would add a LOT of flexibility when measuring.
Thanks for the update and info.
Is the edges control now available in the API?
That’s awesome, @alex!
I have already test that, and it is what I was looking for.
thank you!
Hi @dushyant
Yes, everything edge related is now available through the API in the latest version
We’re still one iteration away from simplifying how you can control edge rendering via options and the like, so until then, it’s going to be more verbose
Let us know if you want more specific guidance on this topic
Cheers
