Has anyone been able to deploy a speckle server on Azure? If so what did you need to set up?
I’ve seen a few posts on Azure AD but not much detail on the actual steps on the deployment.
Any help would be awesome!!
Hey @shuzmm, we’ve seen several, but each have their own set of gotchas depending on the way the organisation sets things up.
We heartily recommend starting with the Deploying a Server - Kubernetes | Speckle Docs way as it in theory it’s the most portable. @shiangoli has deployed to azure recently, and afaik the smart peeps from B+G are also doing the same (cc @AlexHofbeck). @jenessa.man and @JdB from Arup the same.
Sorry for spamming a lot of people
I suspect having some specific questions will help.
Hi guys,
regarding the steps for Azure and Docker, I can provide a PDF beginning of next week. Was already on my to do. Need to make sure that this one is clean with no specifics about our server. Azure Kubernetes is something, we did not take a look at (for now). For Azure Kubernetes @shiangoli and the guys from Arup are better equipped to answer that
Hi @dimitrie, @AlexHofbeck @shuzmm , We have certainly been able to deploy Azure Kubernetes and will share the steps either here or elsewhere which is more appropriate
@shuzmm @AlexHofbeck @dimitrie
Below is an example of the steps you can take to install Speckle on Azure Kubernetes. These are all from the command line and using the portal. For a production build its best to create yaml pipelines which will use the az cli and/or terraform
Pre-requisties
I’ve used powershell for the work
Install the CLI, which will also install kubectl
az aks install-cli
Install Azure Kubernetes
az aks create -n aks-name -g <resource group name> --node-count 3 --network-plugin azure --generate-ssh-keys --enable-managed-identity --kubernetes-version 1.25.6 --os-sku Ubuntu
switch context to the new cluster
az aks get-credentials -n <aks cluster name> -g <resource group name> --overwrite
Install Ingres-nginx load balancer
helm repo update
helm install ingress-nginx ingress-nginx/ingress-nginx --create-namespace --namespace ingress-nginx --set controller.service.annotations."service\.beta\.kubernetes\.io/azure-load-balancer-health-probe-request-path"=/healthz
Once complete check that the ingress-nginx service is up and running
kubectl get service -n ingress-nginx
Create Speckle namespace and install the priority classes
kubectl create namespace speckle
Install Priority Classes
Speckle relies on 3 priority classes Low, Medium, and High. Save each of these as yaml files
Low Priority Class File:
apiVersion: scheduling.k8s.io/v1
kind: PriorityClass
metadata:
value: -100
globalDefault: false
description: "Low priority (-100) - Non-critical microservices"
Medium Priority Class File
kind: PriorityClass
metadata:
value: 50
globalDefault: true
description: "Medium priority (50) - dev/test services"
High Priority Class File
kind: PriorityClass
metadata:
value: 100
description: "High priority (100) for business-critical services"
run the following for each of the Low, Medium and High files to create the priorities
kubectl create --context "aks-name" --namespace speckle --filename .\MediumPriorityClass.yaml
Install Redis
example
az redis create --location <region> --name <redis cache name> --resource-group <resource group> --sku Basic --vm-size c0
Or install Azure Redis Cache from the azure portal
retrieve the primary or secondary access key
Install Postgres
install postgres single or flexible server and enable access to azure services
Create the Kubernetes secret for Speckle
kubectl create secret generic server-vars --context "<aks name>" --namespace speckle --from-literal=redis_url="rediss://:<redis access key> %3D@<redis hostname>.redis.cache.windows.net:6380/0" --from-literal=postgres_url="postgresql://postgres-username%40<pg-host-name>.postgres.database.azure.com:<postgres-username-pw>@<pg-host-name>.postgres.database.azure.com:<port number>/speckle?sslmode=require" --from-literal=s3_secret_key="S3 key" --from-literal=session_secret="s3 secret" --from-literal=email_password="smtp password"
The postgres connection string needs to be in URI format. Please see the following link
Note the gotcha @ only needs to be escaped with %40 in the username not the host
postgresql://user%40host:password@host:port/database?sslmode=require
S3 Compatible Storage using Minio
Azure storage services do not support Amazon S3 storage API hence you will need to install minio to provide that S3 API interface. There are various paths you can take here we’ve opted for Minio on K8s and this is still work in progress and I will update this post once complete
Create DNS and install certificate
The approach will depend on your environment that is requesting a DNS and your certificate provider. Once you have your certificate you need to assign it to a k8s secret that will be used by the ingress
kubectl create secret tls <tls secret name> --key .\<key file>.key --cert .\<certificate file>.crt -n ingress-nginx
kubectl create secret tls <tls secret name> --key .\<key file>.key --cert .\<certificate file>.crt -n speckle
Speckle install
Download the helm values yaml file
https://raw.githubusercontent.com/specklesystems/helm/main/charts/speckle-server/values.yaml
Modify the namespace used for speckle, domain and whether your using the cert-manager and if you are using postgress the database certificate
helm upgrade <speckle server name> speckle/speckle-server --values values.yaml --namespace speckle --install
Check the service is up and running
kubens speckle
kubectl get all
Deploy the ingress into the Speckle Namespace
kubectl edit ingress <speckle server name> -n speckle
change the host and hosts value to your DNS
Also the secretName of your certificate
The external facing IP address of your ingress-nginx loadbalancer
spec:
ingressClassName: nginx
rules:
- host: <DNS hostname>
http:
paths:
- backend:
service:
port:
number: 8080
path: /
pathType: Prefix
- backend:
service:
port:
number: 3000
path: /(graphql|explorer|(auth/.*)|(objects/.*)|(preview/.*)|(api/.*)|(static/.*))
pathType: Exact
tls:
- hosts:
- <DNS hostname>
secretName: <Secret holding the certificate>
status:
loadBalancer:
ingress:
- ip: <External facing IP address>
If all is well you should be able to browse to your DNS hostname. hope the above helps. I noticed this is a personal message, others might find the above useful and I can place this elsewhere
This is great, thanks for writing this up @shiangoli
This is amazing thanks so much @shiangoli. I might start looking at putting all of these into YAML / Terraform files to hopefully make this easier for Azure
@shiangoli I’ve managed to get most of the services up and running:
However I’m getting a specific error when the pod is being probed for readiness
Saying connection is refused on 127.0.0.1:3000
I don’t see anything in the speckle-server YAML that changes any of that. Is this something we need to change to 0.0.0.0?
@shuzmm - the readiness probe is making a request, not listening, so the listen address of 0.0.0.0 would not be appropriate.
This error message is stating that the Kubernetes readiness probe cannot connect to the server at localhost (127.0.0.1).
The Readiness Probe for Speckle Server is an HTTP request made by node to 127.0.0.1. This command is run, by kubelet, from within the speckle server container itself - so it should have access to the container’s local network and not be subject to external network errors or misconfigurations.
You could try amending the readiness probe by editing the deployment in your cluster, perhaps swapping 127.0.0.1 with localhost (which would allow Kubernetes to use IPv6), or the Kubernetes service address, or the pod’s IP address.
My guess at this moment is that the Kubernetes cluster has been deployed with IPv6 enabled, perhaps as a dual stack cluster, and the pod is only locally addressable via IPv6 and not IPv4.
Did anybody have any luck in deploying on Azure? I’m a bit stuck on how to handle the S3 API requirement.
@Nikolaj_Klitlund_Bor - we’ve seen MinIO being deployed on Azure to achieve this requirement.
We’ve also used S3Proxy
perfect! I went with S3Proxy and i was fairly simple, and is working perfectly.
4 posts were split to a new topic: Troubleshooting Speckle File Uploads via MinIO in Kubernetes
Does anybody have an example of a working S3proxy configuration? I have it running in AKS, and I can upload files via the frontend (and see them in the Azure file browser), but after the file has uploaded, I get an error dialog “The file import failed unexpectedly”.
In the logs for the speckle-server component, I see the following error:
"err": {
"type": "FileUploadInternalError",
"message": "Failed to download file feccde9c91. HTTP 404: Not Found",
"stack": "FileUploadInternalError: Failed to download file feccde9c91. HTTP 404: Not Found\n at /speckle-server/packages/server/dist/modules/fileuploads/services/resultListener.js:45:21\n at process.processTicksAndRejections (node:internal/process/task_queues:95:5)\n at async Object.listener (/speckle-server/packages/server/dist/modules/fileuploads/index.js:79:13)\n at async messageProcessor (/speckle-server/packages/server/dist/modules/core/utils/dbNotificationListener.js:63:9)",
"name": "FileUploadInternalError",
"jse_shortmsg": "Failed to download file feccde9c91. HTTP 404: Not Found",
"jse_info": {
"code": "FILE_UPLOAD_ERROR",
"statusCode": 500
I’m a little stumped by how this can happen - the file is there and valid in Azure, so one component can get through to s3proxy but the other can’t?
