Hello, I can seem to be able to send the simplest floor I have created from rhino into speckle. I’m trying to do a test run, as this is my first time to use speckle. I have attached a screenshot of the error i am getting. Help is greatly appreciated. Thanks in advance
Hey @glenn_forspeckle, that’s a fortuitous family name
welcome aboard.
The error message you are seeing is a connectivity one. Are you working from a corporate network, firewall, using a VPN?
I presume you can see our website etc.
If you installed from Speckle Manager, can you see the news feed within there?
thanks for welcoming me!
oh that family name, i just made it up so that the email that I’d be using would be exclusive to anything and everything speckle
didn’t bother anymore to change it
I am running on the simplest home wifi with basic anti-virus, nothing fancy and no VPN either.
I can also see the news feed, i downloaded and installed from the manager
Can you please share with us your logs under: %appdata%/Speckle/Logs ?
Did you try using any other Speckle connector like Revit? Do they work?
Hi there!
Today I experienced I have te same problem, when trying to publish geometry from Navisworks.
Below the errors;
Navisworks
Manager
Any ideas? Thanks in advance!
Hey @D.S_Bosma ,
Could you share your logs?
Has there been any changes to your network, like a corporate VPN or firewall?
Thanks for your report @D.S_Bosma, we have identified a universal issue affecting a subset of users. Apologies, we are now looking at this as an urgent course of action.
I unlogged from Pulgin, and logged back in and it worked.
@Joff_20 ;This worked for me, thanks!
For anyone else facing this problem:
