BIM elements not visible in rhino toolbar
BIM elements button is not visible in rhino toolbar.
Also the ApplySpeckleSchema command is not found in rhino.
I am trying to follow the tutorial here: Stream Rhino Geometry Directly Into Revit
and here: Rhino | Speckle Docs
thank you
Hey @Sindri_Sigurdsson welcome to these parts. Its good to see you.
The tutorial itself needs some updating. I can refer you to the post here
As @gokermu explains, The Schema tools are being replaced by the Mapping tool. This is an improved workflow for creating Revit geometry inside Rhino.
More can seen about this here:
This is a good prompt for us to refresh the tutorials; thank you.
