I recently got this exception “A managed exception was thrown by Revit or by one of its external applications.” when I try to open a document which has been opened using xru.OpenDoc.
The goal of the method I test is to activate one document before closing another. Therefore, in my test, I use xru.OpenDoc to open document A and open document B. Then, I use my method to activate document A and close document B.
However, it does not work like in production environment where the document A can be opened and activated although it is in active state.
Hey @ptran, sorry this post didn’t get attention. I think I moved this to the general discussion as it didn’t seem Speckle-related but more generally Revit add-on problems. But I’m looking again. Are you asking about the XUnitrevit library?
Hi @jonathon , thank you for your attention. I’ll make a note and post any items related to xUnitRevit in ‘General discussion’ later.
Yes, I am asking about the xUnitRevit library.
If it’s a managed exception, it would be helpful to find its stack trace and see exactly where it throws and what the inner exception says, can you do so?
The inner exception message is ‘A managed exception was thrown by Revit or by one of its external applications.’ ,
and for stack trace: ‘at Autodesk.Revit.UI.UIApplication.OpenAndActivateDocument(String fileName) in Autodesk.Revit.UI\UIApplication.cs:line 7010’
To reproduce, here are the steps:
In my tests, I open document A using ‘xru.OpenDoc’. It will return me a doc object.
Then, I use Revit Api to active the same document using the doc object above: ‘uiApp.OpenAndActivateDocument(doc .PathName)’
