Why speckle web don´t show the main root? I have a problem to find it. Help me please
Logs: If the issue regards our desktop connectors, please share the relevant logs you find under:
%appdata%/Speckle/Logs
Hi @angar18, main root can be many things. Can you explain more what you are looking for? Screenshots and as much context as possible will help us guide you.
The “main” model is a legacy operation that was default in speckle.xyz legacy web app.
Our v2 connectors will still produce a main model if you create a project in the connector and not on the web.
If you don’t see “main” for that second project it is probably because there is no data there. The new web app simply hides an empty main model.
Thank´s for your cooperation
