Why is the Saved View feature not available in the standalone deployment version? Does it require an additional license purchase?
Hello Speckle Team,
I hope this message finds you well. I have successfully deployed SpeckleServer 2.27.1 locally, and I would like to seek your guidance on a feature-related question.
Here is my current yml configuration file:
version: '2.3'
services:
  postgres:
    image: 'postgres:16.9-alpine'
    restart: always
    ports:
      - '5432:5432'
    environment:
      POSTGRES_DB: speckle
      POSTGRES_USER: speckle
      POSTGRES_PASSWORD: speckle
    volumes:
  redis:
    image: 'valkey/valkey:8-alpine'
    restart: always
    ports:
      - '6379:6379'
    volumes:
      - ./redis-data:/data
  minio:
    image: 'minio/minio'
    command: server /data --console-address ":9001"
    restart: always
    ports:
      - '9000:9000'
      - '9001:9001'
    environment:
      # 显式设置 MinIO 的账号密码,对应 Speckle 中的 S3_ACCESS_KEY 和 S3_SECRET_KEY
      MINIO_ROOT_USER: 'minioadmin'
      MINIO_ROOT_PASSWORD: 'minioadmin'
    volumes:
      - ./minio-data:/data
  # speckle-ingress:
  #   image: speckle/speckle-docker-compose-ingress:2.27.1
  #   restart: always
  #   ports:
  #     - '80:8080'
  #   environment:
  #     NGINX_ENVSUBST_OUTPUT_DIR: '/etc/nginx'
  #     FILE_SIZE_LIMIT_MB: '100'
  # speckle-frontend-2:
  #   image: speckle/speckle-frontend-2:2.27.1
  #   restart: always
  #   environment:
  #     NUXT_PUBLIC_SERVER_NAME: 'local'
  #     NUXT_PUBLIC_API_ORIGIN: 'http://127.0.0.1'
  #     NUXT_PUBLIC_BACKEND_API_ORIGIN: 'http://speckle-server:3000'
  #     NUXT_PUBLIC_BASE_URL: 'http://127.0.0.1'
  #     NUXT_REDIS_URL: 'redis://redis'
  #     NUXT_PUBLIC_SSL_ENABLED: 'false'
  speckle-server:
    image: speckle/speckle-server:2.27.1
    restart: always
    depends_on:
      - postgres
      - redis
      - minio
    ports:
      - '3000:3000'
    environment:
      CANONICAL_URL: 'http://127.0.0.1'
      SESSION_SECRET: 'your-secret-key-here'
      STRATEGY_LOCAL: 'true'
      POSTGRES_URL: 'postgres'
      POSTGRES_USER: 'speckle'
      POSTGRES_PASSWORD: 'speckle'
      POSTGRES_DB: 'speckle'
      # --- 修改开始 ---
      # S3 API 必须连接 9000 端口,而不是 9001
      S3_ENDPOINT: 'http://minio:9000'
      S3_PUBLIC_ENDPOINT: 'http://minio:9000'
      S3_ACCESS_KEY: 'minioadmin'
      S3_SECRET_KEY: 'minioadmin'
      S3_BUCKET: 'speckle-server'
      # 允许 Speckle 自动创建 Bucket
      S3_CREATE_BUCKET: 'true'
      # --- 修改结束 ---
      FRONTEND_ORIGIN: 'http://127.0.0.1'
      EMAIL: 'true'
      EMAIL_HOST: 'smtp.163.com'
      EMAIL_PORT: '465'
      EMAIL_USERNAME: '[email protected]'
      EMAIL_PASSWORD: '******'
      EMAIL_SECURE: 'true'
      EMAIL_REQUIRE_TLS: 'false'
      EMAIL_FROM: '[email protected]'
  preview-service:
    image: speckle/speckle-preview-service:2.27.1
    restart: always
    depends_on:
      - speckle-server
    environment:
      PORT: '3001'
  webhook-service:
    image: speckle/speckle-webhook-service:2.27.1
    restart: always
    depends_on:
      - speckle-server
      - postgres
    environment:
      PG_CONNECTION_STRING: 'postgres://speckle:speckle@postgres/speckle'
  fileimport-service:
    image: speckle/speckle-fileimport-service:2.27.1
    restart: always
    depends_on:
      - speckle-server
    environment:
      SPECKLE_SERVER_URL: 'http://speckle-server:3000'
The deployment is working well overall, but I’ve noticed that the “Saved View” feature is not appearing in the projects I’ve created. Upon investigating the frontend-2 codebase, I found that the Saved View feature is controlled by the following condition:
export const useAreSavedViewsEnabled = () => {
  const {
    public: { FF_SAVED_VIEWS_ENABLED, FF_WORKSPACES_MODULE_ENABLED }
  } = useRuntimeConfig()
  return !!(FF_SAVED_VIEWS_ENABLED && FF_WORKSPACES_MODULE_ENABLED)
Based on this, I have a few questions that I would greatly appreciate your help with:
  1. Does this mean that a workspace license is required to enable the Saved View feature in self-hosted deployments?
  2. If not, could you please guide me on how to configure the environment variables or settings to enable this feature?
  3. Are there any plans to make this basic viewer functionality freely available for self-hosted versions in the future?
I understand that you have a lot on your plate, and I truly appreciate any guidance or clarification you can provide on this matter. Thank you so much for your excellent work on Speckle and for taking the time to help the community!
Best regards,
zhuzhu
Thank you for your reply. I would like to use this feature—could you please guide me on how to purchase the license, and what the approximate cost would be?
Reach out for pricing for licences to [email protected]
