V3 Archicad Connector Development
Hi, Now that the V3 connector is underway for Archicad can I please ask if there is any plans to sync the archicad custom properties across to speckle? Also syncing up 3D object parameters into speckle.
Archicad is great at creating data but is totally rubbish at making accessible and usable. If we can have access to that data through speckle it will make the extraction and manipulation of this data so much more powerful.
Great insight @Gavin_Pendergrast
Next gen connectors start with a premise of nailing extraction workflows first. So this is a good benchmark for the team to meet.
Hello @Gavin_Pendergrast , welcome to the community!
Our current Archicad next gen connector is still in alpha, but we’ll be adding properties soon. These will be added under a properties field, a standard we are using for all data objects coming out of next gen connectors :slight_smile:
Could you share which properties in particular you are most interested in extracting from Archicad? Screenshots from the application would be super helpful, and help us scope the next phase of archicad development.
