I am currently working on displaying a model created in Grasshopper in Power BI using the Speckle Power BI Viewer. The data in Grasshopper updates dynamically to Speckle and is read by Power BI. However, after updating the data, the Speckle Power BI Viewer would shows both the old model and the new model, while the new model does not replace it. I would like to know how to ensure that the Speckle Power BI Viewer displays the new model and replaces the old one accurately.
Every time that you push a new version in the model you simply need to click the refresh button. This will pick the latest version and update your dashboard.
Thank you so much for your response. I actually did like what you said. But my issue is that in the Viewer, the old one kept being there after I click the refresh button(shown in figures I provided). The first figure is before refreshing, and the second is after refreshing.
Can you please use the Speckle Manager and update the connector to 2.20.1? I am using this version and I have no issues, so it might be a bug in the version that you are using.
The installer for PowerBI 2.20 from Manager also installs the visual!!! S chances are you have it already and just need to add it from the visual file.
Thank you for your patience! I have now added the visual file and am facing a new problem. As I need to show both the model and the edge of the model, I generated some lines to show the edge in GH. However, when using the 2.20 version viewer, the edge of the old model is displayed in white, transparent lines after refreshing. Are there any methods to solve this problem?
Okay, here is my URL: surface with edge - Test1 | Speckle
By the way when viewing the model online, there is no issue mentioned before when generating new model, but in the Power BI viewer, the issue occurs.
