Unable to use speckle on mac with rhino or sketchup after connectors installed
UPDATE - Managed to upload speckle log as attached file
I wanted to test using Speckle to transfer geometry between rhino and sketchup. I downloaded the speckle manager, added my account and installed the connectors, but I can’t access any functionality either sketchup or rhino.
I’m working on a 2021 macbook pro with Sonoma 14.7.1
Please let me know what I might need to do differently.
For sketchup 2023, when I try to launch speckle from the dropdown menu, I receive the following error message in the ruby console. (info for rhino and some screenshots at the end)
Loading Speckle Connector v2.21.1 from build
Error: #<IOError: No Accounts db found. Please read the guide for different options for adding your account:
             https://speckle.guide/user/manager.html#adding-accounts>
/Users/veda/Library/Application Support/SketchUp 2023/SketchUp/Plugins/speckle_connector/src/accounts/accounts.rb:13:in `load_accounts'
/Users/veda/Library/Application Support/SketchUp 2023/SketchUp/Plugins/speckle_connector/src/actions/initialize_speckle.rb:19:in `update_state'
/Users/veda/Library/Application Support/SketchUp 2023/SketchUp/Plugins/speckle_connector/src/app/speckle_connector_app.rb:51:in `update_state!'
/Users/veda/Library/Application Support/SketchUp 2023/SketchUp/Plugins/speckle_connector/src/commands/initialize_speckle.rb:37:in `initialize_speckle'
/Users/veda/Library/Application Support/SketchUp 2023/SketchUp/Plugins/speckle_connector/src/commands/initialize_speckle.rb:28:in `_run'
/Users/veda/Library/Application Support/SketchUp 2023/SketchUp/Plugins/speckle_connector/src/commands/command.rb:22:in `block in run'
/Users/veda/Library/Application Support/SketchUp 2023/SketchUp/Plugins/speckle_connector/src/commands/command.rb:33:in `with_observers_disabled'
/Users/veda/Library/Application Support/SketchUp 2023/SketchUp/Plugins/speckle_connector/src/commands/command.rb:21:in `run'
/Users/veda/Library/Application Support/SketchUp 2023/SketchUp/Plugins/speckle_connector/src/commands/menu_command_handler.rb:12:in `block in sketchup_command'
In rhino 8, when I type speckle in the command link, nothing happens. Looking through the dropdown toolbars makes it seem like it there is no connector or reference to speckle. I’m using the 90-day trial license for rhino, not a cracked version.
As an FYI, I can’t attach the speckle log to this post as a new user and when I tried to paste it as code, the length exceeded the number of characters allowed. Is there another way I can share this info?
Please see below some images showing the speckle manager setup as well as responses in skp and rhino.
SpeckleCoreLog20250228.txt (90.1 KB)
I’ve upgraded your account status @mctvb
For anyone landing here: there are now experimental (alpha) macOS installers for Rhino & Grasshopper and SketchUp (and Blender). Details and caveats are in the changelog post.
