Unable to rename direct shape in Mapper
I am not able to rename direct shape elements in Mapper in Rhino. Every element has the name “Speckle Mapper Shape”. Is this not available yet or is there something I am missing?
Hi Richard, are you setting this field here and it doesn’t reflect in Revit?
The field seems to be locked to “Speckle Mapper Shape” which is reflected in Revit.
I can’t delete it or replace it with the name I want .
I’ve just done some playing and discovered that although I cannot type in that field, I can paste text which stays and reflects in Revit. Woohoo.
Still it adds a bit of time not being able to type the name in.
I take it from the lack of reply that this is expected behaviour and I am just lazy for wanting to be able to type the name rather than cut and paste from notepad?
Not lazy at all and maybe either a limitation, oversight or bug.
All our development right now is away from the UI framework Mapper was based upon because it had some quirky edge cases out of our control. This maybe one of those (it maybe just we got it wrong)
Sorry your appeal slipped through the cracks, we hope when Mapper makes it to nextgen that a fix is implicit. In the meantime happy that you have a workaround and have shared it for others.
