I have successfully connected the speckle stream to Power BI using connector and seeing all the data in table in PBI. I have added speckle visual in PBI as well and added stream url and object id but model is not loading in visual, am I missing something?
This connector is still in very early stages of development so we appreciate your patience
Most of our team is taking a break for the holidays but we will make sure to investigate in early January.
In the meantime, please have a look at the docs in case there is some misconfiguration in your dashboard: Power BI | Speckle Docs
@teocomi Fair enough just discovered Speckle recently and I am impressed with all the interoperability. Actually I am trying to test it for some of my workflows. I offer myself to help the platform to grow testing it and giving my feedback… I work in construction actually integrating 3D models and data and doing analysis in powerBI.
Thanks for your reply and great job to the entire team… looking forward to integrate speckle even more!
sorry about the confusion about this, I’ll add a clear warning on the visual to make it clear, but in essence:
The current viewer does not allow to view data from private streams, as it doesn’t have access to the “login credentials” that were used on the “PowerBI Data Connector”.
We’re working lifting this limitation but we have no ETA for this at this moment.
