`TypeError: l is null` - objectsender
Hey Speckle!
I’m trying to update a Speckle model (from Navisworks) in TS and send the updated model back to Speckle using @speckle/objectsender.
I pull the model using @speckle/objectloader updates a few properties and want to send it back again.
On sending it back I get this (very descriptive) error: TypeError: l is null, which is thrown on line 107 of the Serializer.ts file. Which looks like this:
async #traverse(obj: Record<string, unknown>, root: boolean) {
  // 3. speckle objects
  if ((value as Record<string, unknown>).speckle_type) { //<-- Line 107
    const child = (await this.#traverseValue({
      value,
      isDetached: isDetachedProp
    })) as {
    traversed[propKey] = isDetachedProp ? this.#detachHelper(child.id) : child
    continue
So I’m make sure to have a speckle_type property on my changes - still the same result.
So instead of trying to be fancy and edit the model, I just try to pull the model and save it right away. But I still get TypeError: l is null.
My saving function, which I have had success with in other contexts:
import { send } from '@speckle/objectsender'
  const handleSave = async () => {
    setSaving(true)
    try {
      const result = await send(speckleStateData!, {
        serverUrl: import.meta.env.VITE_SPECKLE_SERVER_URL,
        token: token!,
        projectId: projectId!,
      await createCommit(result, {
        token: token!,
        message: 'Updating Model',
      setSaving(false)
    } catch (e) {
      console.error(e)
      setSaving(false)
      return { error: e instanceof Error ? e.message : JSON.stringify(e) }
Any ideas on where it could go wrong?
Hi Christian
From the syntax of your saving function I am assuming this code is running in React. React is very smart on optimising code and functions that get triggered on users interaction. The TypeError: [x] is null is a common problem that happens when the DOM has not yet been mounted, eg. React runs on a virtual DOM until a very late point.
I would bet that React is packing your function to run at a later moment, and during this packing is probably putting some magic properties (l = null) on your speckleStateData object, who knows why.
I would start by splitting your code between pure javascript, and the React part. One way that I think could work is by having a pure JS object to control the state, and only inside the handleSave function transforming the JS obj to your Base Speckle TS class.
There’s some other info on this issue here. javascript - TypeError is Null? - Stack Overflow
Let me know if that helps
Thanks for suggestion @vwb!
Yes, I am a React kinda guy :grimacing:
So handleSave is a callback for a button onClick event, which in principle means that whatever happens inside handleSave no longer has anything to do with the DOM. And handleSave is fired correctly.
Inspecting (debugging/logging) speckleStateData just before passing it to send reveals that the data looks correct (and Speckle like).
I’ve tried moving the handleSave out of the component, but the error stays the same.
I thought about what you wrote with transforming the JS obj to your Base Speckle TS class.
So I tried to play around with my data a bit and that affects the error and when it occurs in the #traverse() loop.
I’ll test a bit more and see if something comes up :grinning:
So I investigated the issue more digging into my data.
The problem arise because I have a key in my data with a value of null.
Hence TypeError l is null. (the key is not called l, so thank you for mimifiying my data JavaScript…)
Anyways, I looked into the objectsender package and the test cases doesn’t include any null values. If you add nothing: null to generateTestObject in examples/browser/main.ts and run the test it fails, with the error Value is null.
    '@(10)chunkedArr': times(100, () => 42),
    some: new RandomJoe(),
    nothing: null   // line 121
If you update line 60 of utils/Serializer.ts to catch null values everything works well again.
      // 1. primitives (numbers, bools, strings)
      if (value === null || typeof value !== 'object') {   // line 60
        traversed[propKey] = value
        continue
Should I create a PR or is there someone from the Speckle team that want to look at it more?
Oh man, PRs are always welcome!!!
