I’m trying to send AutoCAD block data via the AutoCAD Speckle connector to Dynamo/Revit.
End goal is to be able to send this block data from ACAD → Speckle → Dynamo → extract XYZ → create points → from the points create Toposurface.
As of now I can see the data in the Speckle stream I want to receive in Dynamo…:
…but the Receive node in Dynamo contains no data from the steam:
Speckle link to a small data sample if anyone wants to have a go (I hope it works):
https://speckle.xyz/streams/5c04073e87
Can anyone see what I’m doing wrong here? ![]()
