THREE.Object3D.add: object not an instance of THREE.Object3D
hello
when i import gltf model this error appear
<!DOCTYPE html>
<html>
<head>
    <meta charset="utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=edge">
    <title>Building VR interactives with Three.js</title>
    <meta name="description" content="">
    <meta name="viewport" content="width=device-width, initial-scale=1">
    <meta name="mobile-web-app-capable" content="yes">
    <meta name="apple-mobile-web-app-capable" content="yes" />
    <meta name="apple-mobile-web-app-status-bar-style" content="black-translucent" />
    <style>
    html, body { margin:0; padding:0; overflow:hidden;}
    </style>
</head>
<body>
    <script>
    WebVRConfig = {
      // Forces availability of VR mode.
      FORCE_ENABLE_VR: true,
    </script>
    <!-- Assets we'll need - Three.js, controls, and the webVR manager and polyfill -->
    <script src="js/es6-promise.min.js"></script>
    <script src="js/three.min.js"></script>
    <script src="js/three.flycontrols.js"></script>
    <script src="js/three.terrainloader.js"></script>
    <script src="js/VRControls.js"></script>
    <script src="js/VREffect.js"></script>
    <script src="js/webvr-polyfill.js"></script>
    <script src="js/webvr-manager.js"></script>
    <script type="module">
import {GLTFLoader} from './js/GLTFLoader.js'
//import {FlyControls} from './jsm/FlyControls.js'
//import VREffect from './jsm/vreffect.js'
    // Width and height of the browser window
    var WINDOW_WIDTH = window.innerWidth;
    var WINDOW_HEIGHT = window.innerHeight;
    // Width and height of the surface we're going to create
    var WORLD_WIDTH = 2000;
    var WORLD_HEIGHT = 1900;
    var loader = new GLTFLoader();
    var numberrose1=0
    var myTimeout;
    // Where our lights and cameras will go
    var scene = new THREE.Scene();
    // Keeps track of time
    var clock = new THREE.Clock();
    // How we will see the scene
    var camera = new THREE.PerspectiveCamera(75, WINDOW_WIDTH / WINDOW_HEIGHT, 1, 5000);
    // Position the camera slightly above and in front of the scene
    camera.position.set(0, 0, 100);
    //camera.up = new THREE.Vector3(0,0,1);
    // Look at the center of the scene
   // camera.lookAt(scene.position);
    // Think of the renderer as the engine that drives the scene
    var renderer = new THREE.WebGLRenderer({antialias: true});
    // Set the pixel ratio of the screen (for high DPI screens)
    renderer.setPixelRatio(window.devicePixelRatio);
    // Set the background of the scene to a orange/red
   // renderer.setClearColor(0xffd4a6);
    // Set renderer to the size of the window
    renderer.setSize(WINDOW_WIDTH, WINDOW_HEIGHT);
    // Append the renderer to the DOM
    document.body.appendChild( renderer.domElement );
    // Apply VR stereo rendering to renderer
    var effect = new THREE.VREffect(renderer);
    effect.setSize(WINDOW_WIDTH, WINDOW_HEIGHT);
    var manager = new WebVRManager(renderer, effect);
// data json
fetch('./vases.json').then(function (response) {
    return response.json();
  }).then(function (data) {
    // for (let numberrose1 = 0; numberrose1 < data.data.length; numberrose1++) {
    //   rose1(data.data[numberrose1].name,data.data[numberrose1].positionX,data.data[numberrose1].positinY,data.data[numberrose1].positinZ,data.data[numberrose1].rotationX,data.data[numberrose1].rotationY,data.data[numberrose1].rotationZ);
    function icrenum(num){
   //   myTimeout = setInterval(function (){  rose1(data.data[numberrose1].name,data.data[numberrose1].positionX,data.data[numberrose1].positinY,data.data[numberrose1].positinZ,data.data[numberrose1].rotationX,data.data[numberrose1].rotationY,data.data[numberrose1].rotationZ,data.data.length) ;icrenum(numberrose1++)}, 200);
  }).catch(function (err) {
    console.warn('Something went wrong.', err);
//var tomixerloop=0;
function rose1(nam,pox,poy,poz,rox,roy,roz,lngthdata) {
    loader.load('models/' + nam + '.glb', function (gltff) {
      gltff.scene.children[0].traverse(function (child) {
        if (child.isMesh) {
          if(child.name=="base"){
            child.position.x=pox
            child.position.y=poy
            child.position.z=poz
            child.rotation.z= roz
            child.rotation.x= rox
            child.rotation.y= roy
            scene.add(child);
            if(numberrose1>=lngthdata-1){
              clearInterval(myTimeout)
    }, (xhr) => {
    }, (error) => {
  let example = new THREE.Object3D();
  const geometry = new THREE.SphereGeometry( 15, 32, 16 );
const material = new THREE.MeshBasicMaterial( { color: 0xffff00 } );
const sphere = new THREE.Mesh( geometry, material );
scene.add( sphere );
sdd()
function sdd() {
    loader.load('models/sndan3.glb', function (gltff) {
        if (child.isMesh) {
          console.log("ddddddddddddd")
            scene.add(child);
            console.log("yyyyyyyyyyy")
    }, (xhr) => {
    }, (error) => {
    // URL to our DEM resource
    var terrainURL = "data/Gale_HRSC_DEM_50m_300x285.bin";
    // Utility to load the DEM data
    var terrainLoader = new THREE.TerrainLoader();
    // We'll need this later
    var surface;
    // Create the plane geometry
    var geometry = new THREE.PlaneGeometry(WORLD_WIDTH, WORLD_HEIGHT, 299, 284);
    // The terrainLoader loads the DEM file and defines a function to be called when the file is successfully downloaded.
    terrainLoader.load(terrainURL, function(data){
        // Adjust each vertex in the plane to correspond to the height value in the DEM file.
        for (var i = 0, l = geometry.vertices.length; i < l; i++) {
            geometry.vertices[i].z = data[i] / 65535 * 100;
        var textureLoader = new THREE.TextureLoader();
        var textureURL = "data/Gale_texture_high_4096px.jpg";
        // This goes inside the TerrainLoader callback function
        textureLoader.load(textureURL, function(texture) {
            var material = new THREE.MeshLambertMaterial({
                map: texture,
            // This goes in the TextureLoader callback
            // Create the surface mesh and add it to the scene
            surface = new THREE.Mesh(geometry, material);
            //scene.add(surface);
    // Lights!
    var dirLight = new THREE.DirectionalLight( 0xffffff, 0.75);
    dirLight.position.set( -1, 1, 1).normalize();
    var ambiLight = new THREE.AmbientLight(0x999999);
    // Add the lights to the scene
    scene.add(ambiLight);
    scene.add(dirLight);
    // Detect mobile devices in the user agent
    var is_mobile= /Android|webOS|iPhone|iPad|iPod|BlackBerry|IEMobile|Opera Mini/i.test(navigator.userAgent);
    // Conditionally load VR or Fly controls, based on whether we're on a mobile device
    if (is_mobile) {
        var controls = new THREE.VRControls(camera);
    } else {
        // WASD-style movement controls
        var controls = new THREE.FlyControls(camera,renderer.domElement);
        // Disable automatic forward movement
        controls.autoForward = false;
        // Click and drag to look around with the mouse
        controls.dragToLook = true;
        // Movement and roll speeds, adjust these and see what happens!
        controls.movementSpeed = 20;
        controls.rollSpeed = Math.PI / 12;
    // Render loop
    // This should go at the bottom of the script.
    function render() {
        // Get the difference from when the clock was last updated and update the controls based on that value.
        var delta = clock.getDelta();
        controls.update(delta);
        // Update the scene through the manager.
        manager.render(scene, camera);
        // Call the render function again
        requestAnimationFrame( render );
    render();
    </script>
</body>
</html>
Hey @Moath_Ahmed
Speckle doesn’t preclude side-loading gltf into our viewer (which it doesn’t look like you are using) and while it is Threejs based it isn’t something we have specific resources to help you achieve.
If you are working toward a Speckle use-case, to augment the viewer with your own content, please refer to this recent reply:
