Grasshopper Receive component:
My Grasshopper Receive component fails to load streams. I am successfully logged in according to the “AccDet” component.
I’m getting below error:
1. One or more errors occurred.
The graphql request failed without a graphql response
Policy Failed
An error occurred while sending the request.
The underlying connection was closed: An unexpected error occurred on a receive.
The client and server cannot communicate, because they do not possess a common algorithm
Piggiebacking on Mathias’s post since i got the same error again just now and it looked very familiar. This seems to be related to the stream fetch errors in the Rhino / Archicad connectors i’ve ran into a while ago and reported here:
After getting the error in GH tried receiving in Rhino and noticed that the Rhino connector was also unable to retreive any data:
Hey guys, we’re looking into this - will keep you posted!
If you have any chance, could you please verify you experience the same issues when being connected to a different network?
Could you please also check if reverting to the latest stable version of the connectors the issue persists?
Yes this worked yesterday, but only after all other rhino instances i had opened closed down. This was when i was on the office network connected via docking station. Today via wireless VPN at home, restart didnt work unless i run Rhino with admin rights.
