Stream not found by going for backslash
Dear Specklers,
By hitting the \ instead of / one could create something like this by accident … this branch can also not be deleted in the frontend 1.0. I don’t know if this is an issue for frontend 2.0 as well.
In this is case it would be good to have a red message during the creation of the branches “you are not allowed to use the following symbols”, which prevents you from creating the branch.
BTW: As branches will be models in Frontend 2.0, how is the plan for grouping :slight_smile:? It would be really cool to have something similar :slight_smile:
Best,
Alex
Good catch - this is a bug.
Can confirm it can be:
However the wrong UI component appears in list view:
You will be able to delete the branch via GraphQL and also with SDKs
Can you elaborate?
I mean with that a similar behavior like what frontend 1 had with the “/” … even if the branch is now called model? It is like folders for lots of models and helps keep overview …
MEP/ELECTRIC
MEP/HVAC
MEP/ProvisionForVoids
MEP/…
or to list up structural partial models
STR/STEEL (TEKLA)
STR/CONCRETE (REVIT)
STR/TIMBER (CADWORK)
STR/CONSTRUCTION PIT (REVIT)
STR/…
Group and even better deeper sub-nesting
the dream of every order fanatic :heart_eyes:. Love it @jonathon
