@dimitrie what are your thoughts on updating the connection to the database and Redis to be optionally TLS connections. Non-TLS would be the default still.
I can put in a PR.
I can put in a PR.
@cristi’s the boss now on these
@peter.grainger Hmm, we’re actually using TLS connections in our deployments: We just set POSTGRES_URL and REDIS_URL to TLS-enabled urls.
What changes are you thinking of doing?
Ah, OK. Didn’t realise it was that simple! I’ll try that
@cristi for Redis don’t you have to configure it this way? Using Redis with Node.js (node_redis) | Redis Labs Documentation Center
Otherwise it will use the non-TLS connection?
@peter.grainger That’s the way to configure TLS with client certificates to strengthen the client authentication security beyond username/password.
Most redis providers just give you a connection string that starts with rediss:// (notice the double s), which means it uses a TLS socket, and that is recognized and used by the node redis package (check redis - npm and search for rediss in the page)
Do you need a setup with redis client authentication with client certificates? (in this scenario you should also configure the server to trust those client certificates that connect to it)
@cristi redis indeed only needs rediss:// protocol. However for postgres you don’t use the connection string. The connection string is created from multiple environment variables. So I’m thinking this speckle-server/knexfile.js at b9cbe2e2b43f8707126000ce11898c3f20aa1c60 · arup-group/speckle-server · GitHub
Unless there is a better solution you can think of?
@peter.grainger Yes, there are currently 2 ways of configuring the postgresql connection:
else (i.e.: if POSTGRES_USER or POSTGRES_PASSWORD is NOT specified, then the POSTGRES_URL is used as a full connection url (and can be given with any parameters you need)Example POSTGRES_URL (our connection string in production): postgresql://admin:[email protected]:1337/speckle_db?sslmode=require
I’m blind! I didn’t spot the else! Thanks @cristi all tls’d up.
