by running docker-compose without the -d
attaching to speckle_webhook-service_1, speckle_speckle-server_1, speckle_fileimport-service_1, speckle_speckle-frontend_1, speckle_preview-service_1
speckle-frontend_1 | Starting nginx environment template rendering with ${HOSTNAME} ${PWD} ${OS_FLAVOUR} ${NODE_ENV} ${HOME} ${SHLVL} ${FILE_SIZE_LIMIT_MB} ${BITNAMI_APP_NAME} ${APP_VERSION} ${OS_NAME} ${PATH} ${OS_ARCH} ${}
speckle-frontend_1 | Nginx conf rendered, starting server…
speckle-frontend_1 | openresty 12:49:23.80
speckle-frontend_1 | openresty 12:49:23.80 Welcome to the Bitnami openresty container
speckle-frontend_1 | openresty 12:49:23.80 Subscribe to project updates by watching GitHub - bitnami/containers: Bitnami container images
speckle-frontend_1 | openresty 12:49:23.80 Submit issues and feature requests at Issues · bitnami/containers · GitHub
speckle-frontend_1 | openresty 12:49:23.80 INFO ==> ** Starting OpenResty setup **
speckle-frontend_1 | openresty 12:49:23.81 INFO ==> Validating settings in OPENRESTY* env vars
speckle-frontend_1 | openresty 12:49:23.82 INFO ==> Initializing OpenResty
speckle-frontend_1 | realpath: /bitnami/openresty/conf/vhosts: No such file or directory
speckle-server_1 | [INFO wait] --------------------------------------------------------
speckle-server_1 | [INFO wait] docker-compose-wait 2.8.0
speckle-server_1 | [DEBUG wait] Starting with configuration:
speckle-server_1 | [DEBUG wait] - Hosts to be waiting for: [postgres:5432, redis:6379, minio:9000]
speckle-server_1 | [DEBUG wait] - Timeout before failure: 30 seconds
speckle-server_1 | [DEBUG wait] - TCP connection timeout before retry: 5 seconds
speckle-server_1 | [DEBUG wait] - Sleeping time before checking for hosts availability: 0 seconds
speckle-server_1 | [DEBUG wait] - Sleeping time once all hosts are available: 0 seconds
speckle-server_1 | [DEBUG wait] - Sleeping time between retries: 1 seconds
speckle-server_1 | [DEBUG wait] --------------------------------------------------------
speckle-server_1 | [INFO wait] Checking availability of postgres:5432
speckle-server_1 | [INFO wait] Host postgres:5432 not yet available…
webhook-service_1 | {“level”:“info”,“time”:“2023-03-08T12:49:23.714Z”,“component”:“webhook-service”,“msg”:“Starting Webhook Service…”}
webhook-service_1 | {“level”:“error”,“time”:“2023-03-08T12:49:23.784Z”,“component”:“webhook-service”,“err”:{“type”:“Error”,“message”:“getaddrinfo ENOTFOUND postgres”,“stack”:“Error: getaddrinfo ENOTFOUND postgres\n at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:107:26)”,“errno”:-3008,“code”:“ENOTFOUND”,“syscall”:“getaddrinfo”,“hostname”:“postgres”},“msg”:“Error executing task”}
speckle-frontend_1 | openresty 12:49:23.83 INFO ==> ** OpenResty setup finished! **
speckle-frontend_1 | openresty 12:49:23.83 INFO ==> ** Starting OpenResty **
speckle-frontend_1 | 2023/03/08 12:49:23 [notice] 1#1: using the “epoll” event method
speckle-frontend_1 | 2023/03/08 12:49:23 [notice] 1#1: openresty/1.21.4.1
speckle-frontend_1 | 2023/03/08 12:49:23 [notice] 1#1: OS: Linux 5.15.0-1033-azure
speckle-frontend_1 | 2023/03/08 12:49:23 [notice] 1#1: getrlimit(RLIMIT_NOFILE): 1048576:1048576
speckle-frontend_1 | 2023/03/08 12:49:23 [notice] 1#1: start worker processes
speckle-frontend_1 | 2023/03/08 12:49:23 [notice] 1#1: start worker process 33
fileimport-service_1 | {“level”:“info”,“time”:“2023-03-08T12:49:24.025Z”,“component”:“fileimport-service”,“msg”:“Starting FileUploads Service…”}
fileimport-service_1 | {“level”:“error”,“time”:“2023-03-08T12:49:24.050Z”,“component”:“fileimport-service”,“err”:{“type”:“Error”,“message”:“getaddrinfo ENOTFOUND postgres”,“stack”:“Error: getaddrinfo ENOTFOUND postgres\n at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:107:26)”,“errno”:-3008,“code”:“ENOTFOUND”,“syscall”:“getaddrinfo”,“hostname”:“postgres”},“msg”:“Error executing task”}
preview-service_1 | {“level”:“info”,“time”:“2023-03-08T12:49:24.132Z”,“component”:“preview-service”,“component”:“preview-service/server”,“msg”:“Listening on port 3001”}
preview-service_1 | {“level”:“info”,“time”:“2023-03-08T12:49:24.133Z”,“component”:“preview-service”,“msg”:“
Started Preview Service”}
preview-service_1 | {“level”:“error”,“time”:“2023-03-08T12:49:24.151Z”,“component”:“preview-service”,“err”:{“type”:“Error”,“message”:“getaddrinfo ENOTFOUND postgres”,“stack”:“Error: getaddrinfo ENOTFOUND postgres\n at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:107:26)”,“errno”:-3008,“code”:“ENOTFOUND”,“syscall”:“getaddrinfo”,“hostname”:“postgres”},“msg”:“Error executing task”}
webhook-service_1 | {“level”:“error”,“time”:“2023-03-08T12:49:28.788Z”,“component”:“webhook-service”,“err”:{“type”:“Error”,“message”:“getaddrinfo ENOTFOUND postgres”,“stack”:“Error: getaddrinfo ENOTFOUND postgres\n at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:107:26)”,“errno”:-3008,“code”:“ENOTFOUND”,“syscall”:“getaddrinfo”,“hostname”:“postgres”},“msg”:“Error executing task”}
fileimport-service_1 | {“level”:“error”,“time”:“2023-03-08T12:49:29.060Z”,“component”:“fileimport-service”,“err”:{“type”:“Error”,“message”:“getaddrinfo ENOTFOUND postgres”,“stack”:“Error: getaddrinfo ENOTFOUND postgres\n at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:107:26)”,“errno”:-3008,“code”:“ENOTFOUND”,“syscall”:“getaddrinfo”,“hostname”:“postgres”},“msg”:“Error executing task”}
preview-service_1 | {“level”:“error”,“time”:“2023-03-08T12:49:29.156Z”,“component”:“preview-service”,“err”:{“type”:“Error”,“message”:“getaddrinfo ENOTFOUND postgres”,“stack”:“Error: getaddrinfo ENOTFOUND postgres\n at GetAddrInfoReqWrap.onlookup [as oncomplete] (node:dns:107:26)”,“errno”:-3008,“code”:“ENOTFOUND”,“syscall”:“getaddrinfo”,“hostname”:“postgres”},“msg”:“Error executing task”}
