This is a preemptive bug report because I haven’t pinned down a reproducible minimal example to report as an issue on the repo yet, but I have been getting on client.CommitCreate( new CommitCreateInput() {…}).Result
calls.
There is always a long trace message centred around the Task
While I continue to seek it out, is there any gotcha’s that are known about? Nested null
s and the like? Perhaps a geometry issue, incorrect Base object etc…?
I have started to weed out a bunch of primitive and non-primitive types that don’t serialize which was causing problems but it’s not that.
We did run into some issues, but they were mostly around await
-ing the call instead of calling .Result
. Maybe @AlanRynne has some tricky cases.
Did the send operation for which you want to create the commit for succeed?
Anyhow, if you have a failing example I can take a look.
From memory, I think it did actually complete each time. I ended up try-catching all server calls and this went away enough to get a hackathon demo done. I’ll check if it was an async-await.
Hmm, not sure what could be going on here but would be happy to look into it when you have more details about it!
We’ve had issues with Async/await in the past (specially Grasshopper…) but .Result
seemed to be the way to go.
Also, wrapping your tasks in a Task.Run()
seemed to make GH happy. Not sure if it would be applicable to your case though.
