Hello Speckle team,
I am having issues accessing specklepy.api
Attached the error message…
…and the version of the installed SDK
Thanks in advance for any support.
Michele
Hello Speckle team,
Michele
Hey @smg_michele, welcome back to the forum - you’ve been missed.
I am sorry for the delay in getting back to you. I can see you are running python under windows - can you give more details about your setup? Are you running in a virtual environment, as a jupyter notebook?
How do you install packages usually?
Hi @jonathon, thanks for the reply.
I have python env installed with conda… below a list of the packages, hope that can help
# Name Version Build Channel
annotated-types 0.5.0 pypi_0 pypi
appdirs 1.4.4 pypi_0 pypi
asttokens 2.4.1 pypi_0 pypi
attrs 23.1.0 pypi_0 pypi
backoff 2.2.1 pypi_0 pypi
ca-certificates 2023.08.22 haa95532_0
certifi 2022.12.7 py37haa95532_0
charset-normalizer 3.2.0 pypi_0 pypi
compute-rhino3d 0.12.2 pypi_0 pypi
deprecated 1.2.14 pypi_0 pypi
devtools 0.12.2 pypi_0 pypi
executing 2.0.1 pypi_0 pypi
gql 3.4.1 pypi_0 pypi
graphql-core 3.2.3 pypi_0 pypi
idna 3.4 pypi_0 pypi
importlib-metadata 6.7.0 pypi_0 pypi
multidict 6.0.4 pypi_0 pypi
openssl 1.1.1w h2bbff1b_0
pip 22.3.1 py37haa95532_0
pydantic 2.4.2 pypi_0 pypi
pydantic-core 2.10.1 pypi_0 pypi
pygments 2.16.1 pypi_0 pypi
python 3.7.16 h6244533_0
requests 2.31.0 pypi_0 pypi
requests-toolbelt 0.10.1 pypi_0 pypi
rhino3dm 7.15.0 pypi_0 pypi
setuptools 65.6.3 py37haa95532_0
six 1.16.0 pypi_0 pypi
specklepy 2.16.2 pypi_0 pypi
sqlite 3.41.2 h2bbff1b_0
stringcase 1.2.0 pypi_0 pypi
typing-extensions 4.7.1 pypi_0 pypi
ujson 5.7.0 pypi_0 pypi
urllib3 1.26.18 pypi_0 pypi
vc 14.2 h21ff451_1
vs2015_runtime 14.27.29016 h5e58377_2
websockets 10.4 pypi_0 pypi
wheel 0.38.4 py37haa95532_0
wincertstore 0.2 py37haa95532_2
wrapt 1.16.0 pypi_0 pypi
yarl 1.9.2 pypi_0 pypi
zipp 3.15.0 pypi_0 pypi
The call to speckle.api.client
is correct in your version of specklepy, nevertheless, if you aren’t tied to other specific dependencies, can you try updating specklepy? we are at 2.17.11
conda activate **your_environment_name**
conda install specklepy --force-reinstall
let’s try that and see what next steps might be
Hi again,
I just realized there’s a compatibility issue with python version…the one I have in the env is 3.7
Now works like a charm!
Thanks @jonathon
