Hi would you guys be able to help
im trying to get my Dem tif contour line maps created in qgis into revit
i have seen the QGIS to speckle plugin then to revit but the issue i have is i cannt load the plugin into QGIS
I have set iup the desktop connectors and the acount in specle but no matter which way i try i cannot get it to load correctly
I have seen that Speckle will only work upt to qgis 3.38.2 so i havelodedn this but still it will not load
details are below
my qgi version
QGIS version
3.38.1-Grenoble
QGIS code revision
3d4177afc6
Qt version
5.15.13
Python version
3.12.4
GDAL/OGR version
3.9.1
PROJ version
9.4.0
EPSG Registry database version
v11.004 (2024-02-24)
GEOS version
3.12.2-CAPI-1.18.2
SQLite version
3.45.1
PDAL version
2.6.3
PostgreSQL client version
16.2
SpatiaLite version
5.1.0
QWT version
6.2.0
QScintilla2 version
2.14.1
OS version
Windows 10 Version 2009
Active Python plugins
contour
2.0.14
coordinates_converter
1.0
LAStools
2.1.1
pointsamplingtool
0.5.4
profiletool
4.2.6
quick_map_services
0.19.36
temporalprofiletool
2.1.3
db_manager
0.1.20
grassprovider
2.12.99
MetaSearch
0.3.6
processing
2.12.99
my qgis error meesage
qgis-main’ due to an error when calling its classFactory() method
AssertionError: path not found C:\Users\Andyj\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\speckle-qgis-main\plugin_utils\requirements.txt
File “C:\PROGRA~1/QGIS 3.38.1/apps/qgis/./python\qgis\utils.py”, line 426, in startPlugin
plugins[packageName] = package.classFactory(iface)
File "C:\Users/Andyj/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\speckle-qgis-main_init.py", line 30, in classFactory
ensure_dependencies(“QGIS”)
File “C:\Users\Andyj\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\speckle-qgis-main\plugin_utils\installer.py”, line 231, in ensure_dependencies
install_dependencies(host_application)
File “C:\Users\Andyj\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\speckle-qgis-main\plugin_utils\installer.py”, line 209, in install_dependencies
install_requirements(host_application)
File “C:\Users\Andyj\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\speckle-qgis-main\plugin_utils\installer.py”, line 167, in install_requirements
requirements = get_requirements_path().read_text().replace(“\n”, “”)
File “C:\Users\Andyj\AppData\Roaming\QGIS\QGIS3\profiles\default\python\plugins\speckle-qgis-main\plugin_utils\installer.py”, line 147, in get_requirements_path
assert path.exists(), f"path not found {path}"
Python version: 3.12.4 (main, Jun 10 2024, 12:48:35) [MSC v.1938 64 bit (AMD64)]
QGIS version: 3.38.1-Grenoble Grenoble, 3d4177afc6
Python Path:
C:\Users/Andyj/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\LAStools
C:\Users/Andyj/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins\contour
C:/PROGRA~1/QGIS 3.38.1/apps/qgis/./python
C:/Users/Andyj/AppData/Roaming/QGIS/QGIS3\profiles\default/python
C:/Users/Andyj/AppData/Roaming/QGIS/QGIS3\profiles\default/python/plugins
C:/PROGRA~1/QGIS 3.38.1/apps/qgis/./python/plugins
C:\PROGRA~1\QGIS 3.38.1\apps\grass\grass83\etc\python
C:\Users\Andyj\Documents
C:\Program Files\QGIS 3.38.1\bin\python312.zip
C:\PROGRA~1\QGIS 3.38.1\apps\Python312\DLLs
C:\PROGRA~1\QGIS 3.38.1\apps\Python312\Lib
C:\PROGRA~1\QGIS 3.38.1\apps\Python312\Lib\site-packages
C:\PROGRA~1\QGIS 3.38.1\apps\Python312\Lib\site-packages\win32
C:\PROGRA~1\QGIS 3.38.1\apps\Python312\Lib\site-packages\win32\lib
C:\PROGRA~1\QGIS 3.38.1\apps\Python312\Lib\site-packages\Pythonwin
H:/iCloudDrive/RPAS Filing Cabinet/J file RPAS/job 60 buildwas school
im hoping its something simple but still learning the ropes but this is a crutial part of what we are trying to do with a work project
( i need a topo solid in revit with the contours / land mass for the plan we are creating
you assitance would be apprecaited.
thanks in advance
Andy
