speckle wont load into qgis
H katryno
Thanks all makes sence
So f revit ask I’m using 2025
I have access to 2025 should I try it in there or is yours 2024
I will have a look tonight at the error code as his is a good permissions issue and let you know how I get on
But I understand from above the correct centreing process for revit
How will we know if there’s a revit fix
And is there a way to pos export the speckle file to cab then to revit as a work around at the moment just a thought
Thanks sir far
Sincerely
Andy
@andy_bowden any fixes we make will be fine with both 2024 and 2025 - they are both in our support window.
A post was split to a new topic: Next Gen QGIS connector won’t install
