I guess this is for updating through Speckle Manager ? Has ssl expired ?
Ouch. Thanks for reporting this! We’ll try to look into it. The cert is not expired (https://speckle-releases.ams3.digitaloceanspaces.com/ → the proof; it should be fine in your browser!)
If you’re stuck with downloading updates, you can head over to https://speckle-releases.netlify.app/; the download links in there use https://releases.speckle.dev/installers.
Later edit: if the eset antivirus popup allows you to send feedback, you could try to report it as not dangerous or similar?
Hey @Dimitrios.Ververidis ,
What’s under details, if you click there?
Are you using the “old” manager or the new one?
Speckle Manager v2.2.6
<?xml version="1.0" encoding="utf-8" ?>
<ESET>
<LOG>
<RECORD>
<COLUMN NAME="Time">29/7/2022 2:09:02 ÎĽÎĽ</COLUMN>
<COLUMN NAME="URL">https://speckle-releases.ams3.digitaloceanspaces.com</COLUMN>
<COLUMN NAME="Status">Blocked</COLUMN>
<COLUMN NAME="Detection">Anti-Phishing blacklist</COLUMN>
<COLUMN NAME="Application">C:\Users\jimve\AppData\Local\Programs\speckle-manager\SpeckleManager.exe</COLUMN>
<COLUMN NAME="User">ITI-793\jimve</COLUMN>
<COLUMN NAME="IP address">5.101.110.225</COLUMN>
<COLUMN NAME="Hash">F0A29ABF6D7A1E0A78ED6C90644486E55012DCF5</COLUMN>
</RECORD>
</LOG>
</ESET>
Also the link for the new manager is blocked
https://speckle-releases.ams3.digitaloceanspaces.com/manager2/installer/manager.exe
it seems that NOD32 has put you in the Anti-phising black-list
