Speckle.Core.Serialisation BaseObjectSerializerV2 on large ifc files duplicates objects
  • Objective:
    Here is what i am trying to achieve.
    I have ifc file generated from Revit. i find it difficult to work with speckle server as it has a lot of complications that i dont need. I am trying to convert ifc file to speckle format that i can later use with speckle viewer with SpeckleOfflineLoader
    i’ve managed to successfully parse data from ifc to speckle format json that i later pass to SpeckleOfflineLoader.
    What are you trying to achieve, e.g. Receive Blender data in Excel, Use REST to query comments, …
  • Issue:
    With larger IFC models i see a bug with either objects duplications and/or disposition screenshot 1
    the issue does not exist on ifc file itself as i have opened it with other tools for ifc and there is no object duplications or dispositions
var filePath = new FilePath(ifcFilePath);
            //Ara3D.IfcLoader.IfcFile
            var ifcFile = IfcFile.Load(filePath, true);
            var geometryModel = ifcFile.ToSpeckle();
            //  Speckle.Core.Serialisation.BaseObjectSerializerV2
            var serializer = new BaseObjectSerializerV2();
            var geometryModelJson = serializer.Serialize(geometryModel);
            File.WriteAllText(jsonFilePath, geometryModelJson);
Is there a known error with serialization of large speckle objects or mb there is other ways to achieve my goal?
Curious what are you guys cooking? I’m not remembering any speckle offline loader of ours, so keen to hear more!
Regarding IFC parser, you could check the new one: speckle-server/packages/fileimport-service/src/ifc-dotnet at main · specklesystems/speckle-server · GitHub
Or are you already using that?
I will look into that, is there a way to use this without committing to speckle server? as a standalone dll or something like this as i am already seeing here that it requires this
var projectIdArgument = new Argument<string>("projectId"); var versionMessageArgument = new Argument<string>("versionMessage"); var modelIdArgument = new Argument<string>("modelId"); var modelNameArgument = new Argument<string>("modelName"); var regionNameArgument = new Argument<string>("regionName");
i’ve found this SpeckleOfflineLoader in
import { SpeckleOfflineLoader } from ‘@speckle/viewer’;
it was suggested in one of threads here
so what about using this without need to have speckle server? i just want a simple way to create this processing path
Ifc → speckle base → json
One thing to consider, @Viktor_zhuk:
If your end goal is IFC → JSON → 3D visualization, there are already several tools and libraries (like ifcjs or xeokit) that convert IFC directly to JSON or even load IFC files straight into a web viewer without needing the Speckle object model or serialization layer.
So why go down the Speckle route at all?
Speckle’s superpower isn’t file conversion — it’s structured, interoperable data: objects, relationships, metadata, versioning, and the ability to consume and transform that data across multiple platforms and domains.
If you’re just after “geometry in a JSON blob,” Speckle might feel like overhead. But if you want:
  • Consistent object structures
  • Referencing and relationships
  • Extensible metadata
  • Future interoperability with other authoring tools
  • The ability to publish into collaborative or automated pipelines down the line
…then using Speckle as your intermediate makes sense.
But if your goal is a simple offline IFC viewer and you don’t need all that — other tools might get you there faster and leaner.
Either way, we’re happy to help if you want to experiment more with the Speckle pipeline — but I’m also pleased to point you toward lighter alternatives if that’s ultimately a better fit.
