I am having trouble with speckle compute, where I am trying to send some geometry in a headless environment in meters but am getting it in millimeters. I had the same problem last year when I started with this process but got it fixed using a Python component in the grasshopper script running on compute.
Here is the image of the way I am doing it and the code within the Python script.
I think I might have not explained properly, the solution or workflow I have right now, USED to work when I first did it and worked for a long time up until recently.
Now it doesn’t work and I am unable to set the units to METERS and it’s coming out in the speckle stream as MILLIMETERS.
